Ok i'm installing a cd player here soon, but I need help on where to run the power cord from the battery up front all the way to the trunk? Where in the car do I try to run it thru the car where it isn't to noticeable?
.... Also need to add in that I have no idea where my cd player is going to sit cuz
where it sits now it seems like it isn't going to fit i'm so confused on where it
goes.... does it replace where the holder is or what? guys plz help here i'm so
confused here... thanks
there's a hole in the firewall near the brake pedal i think. just put it there and run it under the door sills all the way to the trunk
either that or run it under the car.
i ran mine from the fender to the door which has the holes for the other wiring for power windows then take the side panels out to put it under the carpet to the back seat
Alright guys thanks i'll try to see which one best suits me or is easiest....lol
i ran mine through a rubber grommet that i slit a hole in under the hood on the passenger side of the firewall. it comes out under the glovebox inside the car and just run it down the passenger side under all the door trim and under the rear seat.
under the ecu on the firewall is a rubber grommet you can use... OR drill a small hole next to your clutch or where the clutch would be if you have an auto trans.. DO NOT go through door jam since closing the door can fray the wire and short your whole car.. you can go under the car but then risk bottoming out and ripping the wire...
safest way is firewall along side the door sills under the carpet then under the rear seat to the trunk.
Ummm... does anyone have a pic of this grommet? where take a picture of where u would or could run it thru at?
door seals and under the carpet
C.N.P. Cars networking people. <---- ask about us
Ok... i think i can do that!
I'm still confused trying to find the place on the passenger side... can u guys help me still i'm lost
Look at yur passenger side firewall see those silver hardlines? Put yur hand on the sidewalk directly behind them now slide yur hand down slowly feel that rubber? Thys your rubber grommet yu need
