Results 1 to 5 of 5
    Default 04-06 ALL Light Bulb Replacement Information
    This is from Sylvania.com (OSRAM SYLVANIA - Replacement Guide - Start). It has a little info about their own bulbs, but it tells you everything you need to know about bulb sizes for the Sentra.
    2006 NISSAN Sentra
    High & low beam headlamp
    H13 (9008)
    H13ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
    H13XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
    Parking light
    3157NA
    Front turn signal
    3157NA
    Rear turn signal
    1156
    1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
    1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Tail light
    1157
    1157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Stop light
    1157
    High mount stop light
    921
    921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
    921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Fog/Driving light
    H11
    H11ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
    H11XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
    License plate
    194
    194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Back up light
    921
    Front sidemarker
    194
    Rear sidemarker
    194
    Dome light
    DE3175
    DE3175LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Trunk/Cargo area
    158
    158LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Plantation, FL
    Thanks! Just bought Super White Bulbs 194 for the licence plate from autolumition.com!
    Quote Originally Posted by Shogunsentra View Post
    Nice, you could also check out Super Bright LEDs ? LED Lights, Bulbs, and Accessories
    VaLadd My06SpecVQ is offline
    Mar 2011
    Oklahoma City
    Cluster bulb type? 04-06
    Quote Originally Posted by My06SpecVQ View Post
    Yeah, so a few bulbs aren't on here. Lol.
    But you may want to read into the cluster mod threads, and report back here when you do find out. I've wondered the same thing before.
  1. 02-03 ALL Light Bulb Replacement Information
    By thesammythecurse in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 04-08-2012, 07:47 PM
  2. Ebay Projector Headlight Bulb Replacement
    By Nerdbot in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 10-15-2010, 08:20 PM
  3. 2000-2007 sentra light bulb size guide
    By Splash45 in forum Sentra Specific Installation Guides & Technical Info
    Last Post: 09-05-2010, 04:42 AM
  4. WTB: singal light bulb clip
    By Splash45 in forum Parts Wanted
    Last Post: 06-25-2010, 03:49 PM
  5. Fog light bulb question.
    By Malarky in forum B15 Sentra (2000 - 2006)
    Last Post: 04-21-2010, 02:54 PM
