Results 1 to 17 of 17
    Andy picabu is offline
    Denville NJ
    Default Instrument panel gauge bulbs
    Finally found some time to look up replacement bulbs for our spec V instrument panels. I had a few burned bulbs that have been bothering me for a long time. Figure I will post the results here for my fellow spec V owners.
    Where to get bulbs: www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs
    Instrument panel: we need (6) bulbs, type #24 ==>(2) will light up the gauges, (1) for the trip computer/ odometer display, (2) for directional signals and (1) for high beam indicator.
    HVAC panel We need (2) type B tall bulbs and (1) type B (T4) bulb. The 2 type B tall bulbs will light up the temperature, fan and temperature selector switches and the type B(T4) will light up the three push buttons.
    They have various color and led bulbs to choose from. I chose incandescent in red because I like the even lighting of incandescent and want to retain 100% of the dimming control. When the bulbs get here I will post pics.
    05 V.O. Spec V w/ Brembo
    Denville NJ
    From left to right: OEM burned type #24 bulb , Pepboys #24 bulb which is same base but much bigger bulb, lummination type #24 oem replacement bulb in red, amber type B (T4) tall bulb for HVAC, 194 wedge bulb in purple, 74 mini wedge bulb in purple.
    Stock burn bulb versus pep boys #24 versus autolumination#24 in red
    stickied..
    Denville NJ
    Please note the Pepboys/ Autozone type #24 bulb is a bit bigger and will produce more heat. If you use it at the odometer/ trip computer, the extra heat will cause the LCD to be all scrambled when the heat build up is too much....for me that's 15 minutes after I turn the lights on. At the other locations it was OK, but I would imagine the extra heat may cause the gauge to burn out sooner than necessary.
    Colton kruton1990 is offline
    Prescott, AZ
    are these the same for an 03?
    Denville NJ
    I am pretty sure they are the same.
    rooo-d :) b15_210 is offline
    dumb question... same for any sentra in general including the 1.8???
    06' Sentra 1.8L
    1/4 Mile Time: All Motor-15.2(BEST)
    1/4 Mile Time: Turbo-Coming Soon!
    Christos Vortexspinny is offline
    New England
    any1 got a clue which bulb to grab? i go o nteh website andi cant find the type #24 bulb anywhere
    Denville NJ
    Quote Originally Posted by b15_210 View Post
    Should be the same for the 1.8 I believe.
    Quote Originally Posted by Vortexspinny View Post
    Go to the page of the #74 bulbs.....1/3 way down you will see the type 24 bulb....it says
    "#74 too big, 194 too small #24 is your bulb" or something like that.
    NOTE: dealing with trying to buy from those people would drive you crazy the want 2 credit cards on your paypal. and if you try and just pay straight up with a card. the time expires 2 fast to be able to buy.. looking for somewhere else to buy
    just ordered all these bulbs and didn't need a second credit card on my paypal account. not to be a dick to this last guy or anything, it's probably just a change in policy since october of last year...
    just wanted to put it out there that i'm going with autolumination because the most popular alternative, superbrightleds.com , sent me license plate and interior bulbs that ended up strobing and freaking out on me (every single bulb but at different times) as well as some cluster bulbs that got too hot and actually burned the red out of the inside of the bulb, returning my dash slowly back to amber-ish.
    good thread, thanks for the reference info. damn near artsy photography
    question for the OP, if you're still getting notifications a year later...
    were the #74's you got from autolumination about the same size as the OEMs? my OEM bulbs look smaller than the ones pictured and the red replacements look somewhat larger, but closer to the ones pictured. there seems to be room for them (they're like 3-4mm taller in the twist lock base) but i worry they will be too big for a reason i can't see in there.
    Mar 2011
    New York, lindenhurst
    i know its a pretty old thread but thanks OP. i replaced my gauge cluster a while back and wanted to do the center console soon but couldnt find what type of bulbs they were. much apprieciated. bulbs already on the way.
    Denville NJ
    Quote Originally Posted by khan View Post
    You need #24 not #74...#74 is a mini wedge and is way too small. #24 from autolumination were same size as OEM.
    Denville NJ
    Quote Originally Posted by Akaragiannis View Post
    I am glad that the post were helpful for u
    Mar 2011
    Question to op, or anyone who has replaced center consoles lights. Ie air condition temp fan ect. One what bulbs did you use. Cause the tall ones I ordered so seem to reach quite right and are barely illuminating gauge. Second. I have now replace all three visible bulbs but I am still getting amber light from defrost button and button below that. The a/c button has no light. So is it only three liights or is there another hidden somewhere. I ordered exactly what op said. Two tall and one type b t4
    May 2011
    I have been looking online for few gauge bulb and someone asked me to purchase NeoWedge 4MM LED Lamp. Now I have a collection of few lights. Yes, its blue LED if you can see.. LOL
    NeoWedge series LED Lamp Specifications
  1. 04-06 Take Apart Gauge Cluster and Switch Light Bulbs
    Last Post: 01-29-2012, 05:30 PM
  2. instrument panel
    By NismoSerSpecv03 in forum B15 Sentra (2000 - 2006)
    Last Post: 06-14-2010, 10:51 AM
  3. Access to Instrument Cluster
    By westner in forum Tutorial Requests
    Last Post: 04-28-2010, 01:07 PM
  4. Philips VisionPlus 9007VP bulbs or sylvania silverstar ultra bulbs?
    By nissanguy04 in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 02-18-2010, 03:26 PM
  5. Replies: 5
    Last Post: 12-28-2008, 12:31 AM
