Results 1 to 20 of 20
    Chris veeeeee is offline
    Coppell
    Default new system what else do i need
    Crutchfield referral code:20 dollars off 200 for new customers!
    ppgup-wa3yr-wtbsy
    AdvancedAutoParts Referral code :save 40% off first purchase 50 dollars or more after promotions, before excluding tax,shipping and core charges. Help a guy out and use my link please
    http://advanceautoparts.tellapal.com/a/clk/3fG8Z3
    My Spec VEEEEEE
    Nov 2010
    http://www.amazon.com/Alpine-PDX-F4-..._bxgy_e_text_c
    buy a nice quality amp, this alpine will give you 4 channels, you can use 2 ch on the front which would be plenty of power and then you the rear 2 chs bridged for a single sub...prob something like a type s 10. its a little more money but that amp will last you many many years and also take up very little room.
    Robert Moparman is offline
    Sep 2011
    Hamburg, Pa
    Alpine speakers are on sale right now at Best Buy. Buy the first pair get the second pair 1/2 off. They have a set of components I have been looking at getting for the front and a 2-way for the rear.
    2005 Ram Hemi 1500: Blacked Out, Debadged, 2/4 Hotchkis Drop, 22" Boss Wheels, Viper Hood, Mopar Intake with Ram Air, Mopar Long Tube Headers, Bassani Exhaust, 3000 stall converter, Trasngo Shift Kit, Drive Shaft Lope, Diablo Programmer, and Zex Wet Nitrous 75 Shot
    2003 Sentra Se-R Spec-V: H&R Sport Springs, Injen Cold Air Intake, Header, Custom Exhaust, 10mm ALK, BSR, 2J Racing Pulley, Centerline Forged Wheels, and waiting for my 2J RSB and Bushings
    Nov 2010
    ive been doing this for almost 2 decades and i have never felt the need to run rear fill, its just that fill! i dump them in every car and put that money into a higher level front pair. it also cuts the need for power on the rear and you can get away with only buying a 4 ch amp.
    Coppell
    Quote Originally Posted by superspec View Post
    Amazon.com: Alpine PDX-F4 4/3/2 Power Density Digital Amplifier: Car Electronics
    well i already ordered the 2 ch amp from crutchfield because i had some credits so both the amp and the wiring kit only cost me 15 dollars. i was thinking if i was going to get a sub that id just get a single mono amp
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
    BC, Canada
    This. Rear fill pulls your sound stage back behind you. How many times do you go to a concert and listen with your back to the band? Its only good for the few times you might have someone(s) sitting in the back.
    Coppell
    lol so no one really answered what i was asking. I already have the amp and wiring kit looking to buy the alpine spr-60c components. I guess i still need speaker wires. and can aftermarket tweeters for in stock location (searched didn't find anything)? I know i'm prob better off making a new spot for them but kinda would rather not have to drill new holes. what other than speaker wires do i need before I install? Do i need those speaker spacer things?
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
    Spring, TX
    I have heard of having aftermarket tweeters in the stock location, don't know how much modification needs to be done though. Looks like you have everything else covered
    Sent via Tapatalk
    Nov 2010
    most of your low to midline component sets will come with another 10+ ft of wire for a tweeter.
    Coppell
    would i just use stock wires going to the tweeters? and rewire the amp> crossovers>woofers?
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
    Jason jasonhobbs86 is offline
    Savannah,GA
    umm you should be able to use the stock wiring. Just run a extra set of wires to the dash and connect them there. Dont go the cheap way out and use electrical tape, get some small wire nuts or some splice caps when you do all your wiring!
    04 Sunburst Spec V Nismo CAI & Cat-Back w/ Brembos + Hawk HPS
    Newest addition: 8000k HIDs - Them SHITS CRUNK!
    $9 STS Mod / Fog Light Mod / Silvia R33 Side Skirts / Painted Valve Cover / Cut BSR Chain! / Gutted Pre-Cat
    Coppell
    Quote Originally Posted by jasonhobbs86 View Post
    lol yea pretty sure shitty wiring caused my friends car to like catch on fire so not gonna skimp on it
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
    Bothell, WA
    Slapped 5 Times in 4 Posts
    What are you going to use to power your sub seeing that you are getting a 2 channel amp?
    Correct me if I am wrong.
    Deck > 2 channel amp > front components.
    If you don't have a sub, get one. Music don't sound good without one.
    ..... << Yuh dun know!!
    Nov 2010
    are you using the factory amp or headunit amp or an aftermarket amp? im personally not a fan of using any factory wire but then again i tend to drive a ton of power through everything and that wouldnt be smart on that 18ga wire. its really easy to run new wire through the door jams so i always do. your antenna makes it realllllly easy. tape wire to end and pull both ends of the boot and fish the wire though. it takes all of about 5 min per door.
    Coppell
    just doing speakers for now if i feel it is lacking ill probably get myself another amp maybe a mono +distribution block and run dual amp for my sub
    Quote Originally Posted by SoundEfx View Post
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
    Coppell
    aftermarket HU +Aftermarket amp
    ppgup-wa3yr-wtbsy
    My Spec VEEEEEE
    Bothell, WA
    That is a good idea. I never liked the idea of one amp running my entire system.
    Nov 2010
    you dont like the idea of using a 6 channel amp or you dont like the idea of using the same channels to power comps and subs?
    Savannah,GA
    yeah, its all about money, from what i saw he was using, i figured he wasnt trying to pull new wire to everything.
    But I will say this, Being a Low Voltage tech, If i ever upgrade past the HU, i will run new wires all the way, usually 16-18ga from the components to the 4ch amp, Run a 4gauge from the amp to the battery, definitely fuse it within 6-12inches from the battery. Put your grounds withing 12 inches of your Amps (the shorter the better) and bolt them to anything with bare metal to ground. Run 3 quality sets of RCA Cables from the HU to the trunk, Two for the component channels and one for the sub channel. You really should have two amps, a 4ch and a Mono 1ohm single channel amp. It is best to buy two dual voice coil 4ohm subs so when you series them down, you get 1ohm and your amp is running at the best it can. Also it would be wise to invest in a Active Crossover for the component channels to tweak them in just right.
    This is just how i've done it to many many many vehicles over the years....
    Savannah,GA
    On a side note.... run your power wire from the battery on the opposite side of the car as to not run the RCA cables and speaker wires next to it.
    power wire on the drivers side and all signal wires on the passenger side.
  1. Exhaust System
    By jamaul08 in forum B16 Sentra (2007+)
    Last Post: 07-20-2010, 09:23 AM
  2. system install
    By nizspecv06 in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 07-15-2010, 08:16 PM
  3. catback system
    By c_jenks04 in forum Parts Wanted
    Last Post: 06-02-2010, 06:01 AM
  4. Fuel System
    By 2k4spec in forum Forced Induction & Supporting Modifications
    Last Post: 05-03-2010, 04:47 PM
  5. my new system
    By viper_fan in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 12-17-2006, 10:35 AM
