Hey guys i replaced my dome,map,and trunk lights with led bulbs and they look nice and really light up the car but they no longer go on and the switch to lock the doors and the alarm no longer work so i have to lock doors manually. I figure i blew a fuse or fuses but The map that says which fuse is for what thing isnt very helpful so if anyone can help by supporting a picture of an 02 gxe fuse box with the fuse(s) i need to replace circled would be awesome and very helpful bc i dont want to be pulling the wrong fuse(s). Thanx in advance![]()
" live today with no regrets, for it may be your last, because tommorrows never promised."- Matthew Molina
There's no problem pulling the fuse one at the time. Just make sure you put it back properly.
I suggest, you look at the map and check the most possible electrical/lighting fuse. Pull it one at a time and check. And if nothing works, try checking the box under the hood.
And it doesnt hurt to upgrade the fuse(s).
Sent via mobile USPS
The fuse that you need to replace is under the hood in the box next to the battery. I believe it is labeled Room Lamp.
Here's a picture of it.
