like the title says. any one ever do one?? i kinda want to do one. The are pretty cheap on ebay. Not bad either come with 3 year warranty's for $30. for instance.....eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
any input? thanks guys.
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
clutchmasters stage 2 clutch
JWT flywheel
2005 SE-R ALTIMA
ebay intake with K&N filter
racingline sturbar
Racingline y-pipe
NWP block off plate
There are a few guys on here with some. In fact, that is the only size that will fit without major dash/console work/remodeling.
<< Yuh dun know!!
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
Keep in mind that you do get what you pay for. Sometimes cheap isn't the best thing.
But who knows, this deck might last you years. Good luck though.
I am getting one as well, but with navigation.
<< Yuh dun know!!
niceyeah idk all the ones i see on ebay are priced around there. i even seen one that a member has i really like it but doesnt ship to hawaii -_- lol. But hey i have a after market deck already and have another i can pull outta our civic. so i have a back up if i need to send that flip out for warranty.
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
Then you are set. What system to you have behind that?
<< Yuh dun know!!
shit i cant remember the speakers i have some new european brand ill send it to you when i go down to the civic. Im swapping it over to the spec. not sure if i wanna put the sub in to.......i think i might go with 4 8-s.........yes 4 8's.........that equivalent <----fail......to a 32in sub or 2 16'slol. if u get the right kinda sub. they are cheap to lol. $50 a sub right now on amazon. and i need a new amp the on in the civic is kinda cheap. it turns off if i blast it to long and it gets hella hot. but sounds good and hits good. i just have 1 RE audio 10 right now.
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
Well the amp in the civic might be cutting out because of heat or low voltage.
Make sure that the amp is getting enough 'juice' while you are banging your system and keep it in a cool space. Maybe put some fans around it and who knows, it might be a better amp than you think.
<< Yuh dun know!!
sometimes it cuts out with the seat even down lol. its mounted on the back of the rear seat idk its ok but i read the receipt and its only 600watts. and the speakers are FLI audio. They are HELLA good. Id recommend them. im swapping the speakers and 6 x 9's over to the sentra and also doin their tweeters. then just gunna run a amp to the speakers and be happy. might see about custom mounting some 8's in the trunk.
here is a link to FLI audio check em out
http://www.fliaudio.co.uk/
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
The only thing holding me back from getting a flip screen is that it gets in the way of the vents...
Its like you can have a/c OR radio.. not both lol
On a side note, how are you liking that RE 10" I'm contemplating trying one..
Sent via Tapatalk
How are you mounting 6.9's in the b15? Why not get 6.5's and not have to create special special mounts?
<< Yuh dun know!!
I hear you molten. I don't like the ac directed straight towards me, so those vents will be closed as much as they can when the screen is up.
<< Yuh dun know!!
Lol @ 4 8" subs the same as a single 32" (or even 2 16"). No matter how many small subs you use, your frequency response is still limited.
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
yes but have you ever seen 4 8's??
3 RE 8 inch subs - YouTube
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
Yeh, the B15's are 6.5 all around if I am not mistaken.
So come components in the front with some 2-ways in the back and your internal sounds should be done.
<< Yuh dun know!!
ugh wtf?! lol so im putting in smaller speakers? well the FLI audio speakers i have now will blow my stock system outta the water lol. I upgraded to some kenwood front speakers but after the got broken in they sounded great for maybe a day. idk maybe i just got used to the bose in the altima lol.
2004 SE-R SPEC-V
NISMO intake
NISMO suspension
NISMO short shifter
NISMO bushings
NISMO header
Apexi N1 Exhaust
PnP IM and PnP TB
2j-racing Pulley
JWT flywheel
2005 SE-R ALTIMA
racingline sturbar
Racingline y-pipe
NWP block off plate
