Results 1 to 3 of 3
    PA
    Default Android tablet Head Unit
    I recently was give a cheap android tablet and I have no use for it currently. I got an idea to strip it and use it as a headunit. I remember seeing a couple of people doing it online and after a little bit of research it seems pretty simple.
    Strip down the rather bulky tablet and create a screen flip up out of the map pocket.
    Simply connect the headphone out to an external channel processor mounted in our lower din for dedicated volume control.
    Hifonics HFEQ 4-Band Equalizer with 9-Volt Line-Driver and
    Then simply drive the speakers with dedicated amps.
    Only downside is powering the device on and waiting for boot unless standby mode will last awhile. And I can charge it by hooking it up to the acc on.
    Discuss?
    Honolulu, Hi.
    how big is the tab? idk might be cool but might look weird. but do it! lol
    2004 SE-R SPEC-V
    NISMO intake
    NISMO suspension
    NISMO short shifter
    NISMO bushings
    NISMO header
    Apexi N1 Exhaust
    PnP IM and PnP TB
    2j-racing Pulley
    clutchmasters stage 2 clutch
    JWT flywheel
    2005 SE-R ALTIMA
    ebay intake with K&N filter
    racingline sturbar
    Racingline y-pipe
    NWP block off plate
    PA
    One I got is 7"
    I've seen someone put a 7" lcd in the map pocket before. But unfortunately no write up. Probably could rig something up with a dvd track and a pivot point.
    If I do decide to do this I'll have to wait till I amplify my whole system. Or I could do it now and test how I like it just using my stereos aux in. Still need to figure out the top bin.
  1. 04-06 Fosgate head unit
    By sannitig in forum Parts Wanted
    Last Post: 02-25-2011, 04:15 PM
  2. All B15 Models head unit upgrade
    By 02SPEC- in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 02-03-2011, 03:22 PM
  3. head unit upgrade
    By SilverSPEC02 in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 12-22-2010, 09:04 AM
  4. head unit problem
    By SE-R Kid in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 10-27-2010, 08:26 PM
  5. New Head Unit
    By hotrod40hec in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 08-18-2009, 08:46 PM
