So I just ordered a full set of hids for my car 2003 spec v, and I ordered the 9007 hi lo relay, has anybody used this before I thought it was necessary? But the real question was, what does everyone do about the factory plastic clips that holds the bulb in place the back side of the bulb is to wide for the plastic clip to slide over?
Just wondering if anyone had this problem and what they did?
my low beam only fit just fine, hopefully the high low does too, im hoping to upgrade to that soon as my money allows
Nismo cold air intake, Nismo header, Nismo lower tie bar, Nismo rear sway bar, Edge downpipe, Greddy evo 2 exhaust, Ksport coilovers, 2-J racing anti lift kit,2-J lightweight crank pulley, FI-R shifter bushings, Rob's air diversion panel, Rob's LTB wheel hop aid, custom Rob's short shifter, More to come!
Bsr, nissport adapter, quick lift hood struts, j30 front calipers yet to be installed…
The high low are a bit bigger and a pain in he butt to mess with. I had a set from them and got rid of them. There low beans are the stuff! Love them had them for years and no problems. The high low are bright but kept acting dumb. I would had recommend you got the low hid high holigen bulbs. Alt less hassle.
