Results 1 to 17 of 17
Thread: What is wrong?
    Joel almost898 is offline
    Jun 2010
    Default What is wrong?
    im new to the sentra world as of last month. i own a 05 ser. everything is going great minus this problem. on launches especially the car would stall out and blow the 10 amp eccs fuse. i replaced it with a 15 and the car sometimes still bogs out like it wants to stall. i have no clue what the problem is. any ideas or suggestions?
    Bothell, WA
    Slapped 5 Times in 4 Posts
    Did you do the header and valve screw fix?
    ..... << Yuh dun know!!
    Jun 2010
    i didnt. and i have no clue if it was previously done
    Bothell, WA
    If you still have your stock header with pre-cat, then it might be the pieces getting into the engine that is causing the issues.
    The blowing of the fuse is puzzling me though.
    If one of the screws come loose and get into the engine, that can cause all kind of trouble, including bending a valve and causing the car to stall.
    Are you getting any codes?
    Jun 2010
    checked it out a couple weeks ago. no codes. trying again tuesday. could the stalling be from a bad ground or cam sensor?
    Bothell, WA
    Unless you know that you installed other electrical stuff, it might be a bad ground. That would explain the blown fuses.
    alexis b1ynd is offline
    P.R.
    Quote Originally Posted by almost898 View Post
    Would you mind if I ask you what fuse are you blowing also did you checked for codes, some malfunctions does not turn the Check engine light on so a nice code reader would help if you have a nissan service manual.. and by launch you mean normal start stop or only hard launches?
    Jun 2010
    strangest part is the car runs fine when driven economically haha. like today for instance drove over railroad track, was in 2nd, gave it some gas to continue on and it starts bucking. im fucking confused
    Jun 2010
    the 10amp eccs fuse. and on hard launches. stopped blowing them once a 15 was put in
    P.R.
    any weird noises? Because my 240SX had a similar problem would drive nice economicly and if i floored it i would hear sounds that sounded like a missfire and fireballs sometimes it was a ground problem ground kit fixed it, and in my spec the same happened but no missfire sound it only stalled on the lights sometimes and in toll stations i cleaned my grounds and ordered a ground kit no problem since but the fuse thing is puzzling none of my cars has done that
    P.R.
    hmm if that is the engine control one you should check your grounds then your harness check for broken wires or something
    Jun 2010
    cam sensor?
    Jun 2010
    maybe?
    P.R.
    sounds unlikely since your check engine light is off, but if you have a nice code reader read the voltage signal its throwing and see if its the correct one...
    Supporting Vendor
    Oct 2008
    Sounds like a bad ground or bad positive or negative connection on the battery terminals.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Jun 2010
    alright thanks man.
    yea I'd try cleaning the posts on the battery and make sure they arent loose in the battery
    Blowing fuse probably has to do with broken insulation on a wire and it comes in contact when it stretches due to the engine movement while you launch.
  1. FML! WTF is wrong?!?!
    By Cappasjr in forum B15 Sentra (2000 - 2006)
    Last Post: 04-07-2010, 03:40 PM
  2. header gone wrong...
    By 02SilverSpecV in forum Naturally Aspirated (NA)
    Last Post: 02-11-2010, 01:33 PM
  3. Possible Ideas on whats wrong?....
    By 2k4spec in forum B15 Sentra (2000 - 2006)
    Last Post: 11-05-2009, 11:53 AM
  4. Replies: 4
    Last Post: 04-17-2009, 03:17 PM
  5. What is wrong with my SES?
    By chinatta in forum B15 Sentra (2000 - 2006)
    Last Post: 03-03-2008, 02:58 PM
