Closed Thread
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: y no boost
    Sep 2011
    Unhappy y no boost
    hi,
    have installed boost gage recently, and uder full trhottle car goes to zero boosts. what gives?
    2004 nissan spec r sentra v. has cold airs and heddars, and short shifter. would short shift keep it from boosts? it says 0 on gage, maybe not hooked ^ rite?
    Apr 2009
    maybe if you push harder on the gas pedal it'll move past zero..
    Preston
    My Photo Album
    My flickr
    StanceWi.com
    TheSpecvBoard.com
    TDMImports
    Ravage Performance
    2004 Nissan Sentra SE-R SpecV
    Quote Originally Posted by Specv118
    this needed more kanye west reference.
    example: Darson your build is cool and all and ima let you finish but Travis has built the best car of all time! all time!
    Sep 2011
    REMOVE cARPET??! is waht u mean??
    i push peddle so hard i stand up!!
    Apr 2009
    Push your seat back.. open the sun roof.. and push harder...
    I dont see the problem here.. y u no go faster.. cuz brokecar..
    Preston
    My Photo Album
    My flickr
    StanceWi.com
    TheSpecvBoard.com
    TDMImports
    Ravage Performance
    Sep 2011
    if push seat back farthur cant reach shift throw shifter handle lol im 5'9 lolol
    wats wrong???!! have plenty o vacuuum but no boosts y?!!
    Apr 2009
    Quote Originally Posted by dbcooper25liter View Post
    Preston
    My Photo Album
    My flickr
    StanceWi.com
    TheSpecvBoard.com
    TDMImports
    Ravage Performance
    Lucas Specv03 is offline
    NH
    Slapped 2 Times in 1 Post
    teehee
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Quote Originally Posted by JVSpecV View Post
    A twin charged, 6 wheel awd, center steer, sqr powered spec v with n2o is no laughing matter.
    Sacramento
    less than three you preston
    Apr 2009
    Quote Originally Posted by L.E.Sentra View Post
    less than three you miles
    Preston
    My Photo Album
    My flickr
    StanceWi.com
    TheSpecvBoard.com
    TDMImports
    Ravage Performance
    aaron specvt06 is offline
    Lafayette Tn
    Seriously?
    Sep 2011
    ya seriusly. was wrong with my boosts?
    car has big moter, should make good boosts no?
    Lafayette Tn
    Post a pic of under your hood
    Jan 2009
    Hagerstown
    I dont know how your car is but i had to take a hammer and dent where the pedal goes i would get about .5psi then i dented the floor where peddle stops and made it better...Also if you use octane booster (5 bottles per fill up) it helps alot too...Hope this helps
    (2009) 50trim (2010) Procharger c-1 (2011) 60-1 Garrett
    Fred fredcase is offline
    Jul 2011
    edmonton ab
    I think its your fuel pump,
    have you tried yelling at it?
    have you tried swearing at it?
    have you tried hitting it?
    AEM CAI, diy polished intake, nismo header, tunepros downpipe, stromung catback, jwt bsr, 2j cp, es mmi, robs whi, 300zx big brakes front, 12.3" big brakes rear. 2j rear sway bar is in the mail.
    Plantation, FL
    Because you need to put madtytehellaflushstancenation stickers on it. Each sticker gives you 1lb of boost. Youll get 5lbs for every sesame street character holding a turbo sticker.
    Hope this helps. Oh also E85 would work miracles adding boost, and make sure you pour some sugar into the gas tank. MOAR POWA!!!!
    Sebastian QR25DE_SpecV is offline
    Jun 2010
    Austin, TX
    Troll, or retard?
    Erick ErickB15 is offline
    Nov 2010
    Honduras
    Maybe u dont have a turbo badge.
    you know u have to add one to make it work, right?
    Yea my English sucks , deal with it!
    Slapped 13 Times in 12 Posts
    You need to add more heddars, try installing on on the back of the motar and you will get the moar powar, too much vacuum is no good, the gauge should always be on zero unless you make boost.
    St. Louis, MO
    Quote Originally Posted by red02v
    I do miss that rush when you hit the go button, turbo cant touch that!
    2002 Mystic Green Sentra se-r shell and a bunch of other goodies for sale - $1500! PM if interested.
  1. How little boost?
    By Seroke in forum Forced Induction & Supporting Modifications
    Last Post: 07-13-2011, 11:45 AM
  2. help no boost.
    By vinceqrbeast in forum Forced Induction & Supporting Modifications
    Last Post: 08-09-2010, 08:57 AM
  3. Boost Problems - Car Stumbles Under Boost
    By Ponda in forum Forced Induction & Supporting Modifications
    Last Post: 06-07-2010, 09:30 PM
  4. Might boost it, again...
    By executiV in forum Forced Induction & Supporting Modifications
    Last Post: 01-28-2009, 04:16 PM
