Lol. I run 3000k for my fogs I like the yellow look with my 5000k headlights.
Nismo cold air intake, Nismo header, Nismo lower tie bar, Nismo rear sway bar, Edge downpipe, Greddy evo 2 exhaust, Ksport coilovers, 2-J racing anti lift kit,2-J lightweight crank pulley, FI-R shifter bushings, Rob's air diversion panel, Rob's LTB wheel hop aid, custom Rob's short shifter, More to come!
Bsr, nissport adapter, quick lift hood struts, j30 front calipers yet to be installed…
nice. i want to just blind everything in sight... lights are more for seeing for me, than the astethics.. i just got lasik surgery, i have to say at the moment, its hard to see/drive at night..
Ah, I understand, installation should be pretty easy to see how to modify the ground wire, but if you have any problems just ask and I'll try and help out the best I can.
I got HID for both head light and fog light, head light 6000k and fog light 3000k with painted fog lens with krayola yellow glass paint.
Sent from my iPhone using Tapatalk
2005 Sentra Ser Spec V
2001 S2000 AP1
great, so i finally installed the HID for the fogs, but i am having a problem where only one turns on, one or twice both left and right lamps came on once (maybe twice)... do i need that relay harness thing to deal with this problem?
Sounds like you got loose connection somewhere near the plugs!
2001 S2000 AP1
