Results 1 to 16 of 16
    Sep 2009
    Default Noise coming from front left wheel.
    There is a noise coming from my front left wheel.. At first it was a sqealing noise when pressing the brakes to slow down/come to a stop..but now it's a rubbing or rolling noise coming from the same area. I think my gas mileage is being affected.
    Anyone know what this problem and the fix is?
    adam willms81 is offline
    Copperas Cove, Tx
    Slapped 2 Times in 2 Posts
    Check your brakes to see if they are dragging. Could also be your wheel bearings possibly.
    Sent via Tapatalk while driving your Mom's car, eating a cheese burger, and street racing.
    Nitrous is like a hot girl with STDs, you know you want to hit it, but you're afraid of the consequences...
    Quote Originally Posted by skwirl View Post
    That's because its impossible to be pretentious when you're driving a sentra. Being an elitist sentra owner is like thinking you're the smartest kid in the special ed class.
    Sep 2009
    Let me add that the squealing would use to happen when I pressed the brakes to slow down.
    Car has 38k miles.
    Spring, TX
    Probably your brakes. You'll never know until you get under there and get your hands dirty though
    Sent via Tapatalk
    Slapped 13 Times in 12 Posts
    Rolling noise is definitely wheel bearings.
    Bothell, WA
    Slapped 5 Times in 4 Posts
    Quote Originally Posted by B15NewYork View Post
    If it is continuous. But if it only happens when stepping on the brakes, it might be something else.
    Hopefully it isn't both bearings and brakes.
    ..... << Yuh dun know!!
    Aug 2011
    I have the same problem excepting goes away if I press down on the brake or goes away around 50mph or so
    Colton kruton1990 is offline
    Prescott, AZ
    Quote Originally Posted by PGFD 01-2.0 View Post
    see if your lug nuts are nice and snug. mine came loose over the weekend and made a rubbing noise till a certain speed and went away when i hit the brakes
    The bearing on the passenger driveshaft can go out too. Had a grinding/whining noise from 15+ mph. Then again he just has it on the left side so it's probably the wheel bearings.
    02/03 non-NATS ECU to 04/05 non-NATS ECU swap harnesses
    Sep 2009
    I checked it out. The rotor wiggles... And when I put the wheel back on while the car is jacked up, the whole wheel moves... Is this a bearing problem?
    Spring, TX
    Quote Originally Posted by ORANGE View Post
    Rotor moving is no b
    Problem cus the wheel holds it on, but when everything is bolted up and still moves (side to side) then yes, that's a bearing issue
    Sent via Tapatalk
    Sounds like a bearing issue to me.
    Feb 2012
    Just happened on my passenger side. Was bearing for me. Cheap and pretty easy to fix.
    Sep 2009
    How easy was it?
    If you're mechanically inclined, here's a how-to:
    How to: Front Wheel Bearing Replacement
    Feb 2012
    Ballston Lake NY
    Just replaced mine on same side. Was doing the exact same thing you described. All quiet now. Easy fix.
  1. Wts 02-03 front bumper new! Left Fender $170
    By Specvay in forum Parts for Sale
    Last Post: 09-27-2011, 11:42 AM
  2. moaning noise and wheel vibration
    By DrivingZen in forum Troubleshooting and Support
    Last Post: 07-08-2011, 12:29 PM
  3. wierd vibrating noise coming from under the car
    By sentrakidd09 in forum B15 Sentra (2000 - 2006)
    Last Post: 09-18-2010, 09:35 PM
  4. QR25DE Whistling noise coming from rear
    By torquejumper in forum B15 Sentra (2000 - 2006)
    Last Post: 02-20-2010, 03:20 PM
  5. weird noise from left front tire
    By SER_2NR in forum Suspension, Chassis & Braking
    Last Post: 12-12-2009, 04:13 AM
