Results 1 to 20 of 22
    Aug 2009
    Slapped 2 Times in 2 Posts
    Default Help w/ electrical stuff
    well my original issue was resolved now this is another electrical issue that i've had for quite some time. My front cig lighter port doesn't work. the one next to the ebrake works fine.
    how can i find what is the cause? possible connection? or can i splice the wires for the one that doesn't work to the one next to the ebrake?
    thanks
    chris
    Bothell, WA
    Slapped 5 Times in 4 Posts
    I don't think that all those things are on one circsuit, hence one fuse.
    Check the fuse box behind the coin tray under the steering wheel.
    ..... << Yuh dun know!!
    Check #10 fuse behind the coin purse. The doorlocks and rear defogger is controlled by the smart entrance control unit. That fuse powers the "ignition on" signal to the control unit which then powers the defogger/door lock relays. The "ignition on" signal is used so that the unit knows that you put the key in the ignition on position before you can operate any of those.
    Also check #12 for the door locks.
    02/03 non-NATS ECU to 04/05 non-NATS ECU swap harnesses
    Pete L8YBUG is offline
    Jan 2011
    Anoka, MN
    Slapped 10 Times in 5 Posts
    mine did the exact same thing and it was due to a bad ground cable connection after my battery relocate
    Aug 2009
    thanks for the quick response, its too dark now to check it, but i'll try to get to it later if i feel like being outside.
    thanks again
    Aug 2009
    Question
    which fuse is the # 10 and # 12?
    heres a pic of the back of my coin holder
    Aug 2009
    damn i can't believe its been 2 months since i had this issue but i got around to switching out the fuse on 10 and 12 w/ the spare and it still didn't work. my keyless remote, rear defroster, my unlock buttons, and my dome light when set to door doesn't turn off, all still do not work.
    anything else i can try?
    someone said try to use a new ground?
    Look into a new smart entrance control unit.
    Aug 2009
    Bump
    Check all grounds
    Mike darkstarxi is offline
    May 2011
    Englishtown, NJ
    I had this same exact problem. There's a fuse in the fuse box under the hood that needs to be replaced. I can't remember what it was called exactly, but I think it was something like Room Lamp. That's the one.
    Aug 2009
    thanks for the help, i'll check it out when i get out of work and let ya'll know how it goes
    chris
    Aug 2009
    Quote Originally Posted by darkstarxi View Post
    this guy got it, everything works again!!! Thanks for all the help
    Aug 2009
    bump, new issue stated in 1st post
    May 2011
    Englishtown, NJ
    Check the power socket and cig lighter fuses behind the coin tray.
    Aug 2009
    Quote Originally Posted by 04flspecvq View Post
    the one that says cig lighter, does that control both?
    do you know what the power socket controls?
    May 2011
    Englishtown, NJ
    I'm not sure which is which, but I see no harm in checking both...........
    I would guess that the one you're having a problem with is the one labeled cig lighter, but your guess is as good as mine.
    It should take less than a minute to pull the two fuses and make sure they're good.
    Aug 2009
    alright, i'll check both but i was thinking that if its possibly a fuse, wouldn't the cig lighter port near the ebrake not work?
    May 2011
    Englishtown, NJ
    Not necessarily. There are two different fuses. Just check them. It only takes a minute.
  1. electrical problem....
    By moltenb15u in forum Troubleshooting and Support
    Last Post: 12-04-2011, 05:52 PM
  2. All B15 Models FS: EBC Green Stuff, OEM STuff,
    By fullah in forum Parts for Sale
    Last Post: 11-15-2011, 10:16 PM
  3. QR25DE Electrical Issue?
    By ISOctSpecV in forum Troubleshooting and Support
    Last Post: 09-27-2011, 11:19 AM
  4. Electrical?
    By 04ky4spec in forum Troubleshooting and Support
    Last Post: 02-23-2011, 12:56 PM
  5. FS: Apex'i Neo, Innovate SSi-4, other stuff. WTB stuff too
    By illestfob in forum Parts for Sale
    Last Post: 10-15-2008, 08:54 AM
