Results 1 to 13 of 13
    Jan 2012
    Queens New York
    Default Electrical - How many people here have an alternator that is rated more than 80 Amps?
    i was brought a 400W punch amp.. im just wondering if the stock alternator is enough to power this amp on top of the HID's and stuff.
    will i have trouble with the stock alternator? i think the stock alternator has a 80 amp output..
    if you guys have links for alternator rated more than 80 Amps, would very appreciate that and your comments on amp ratings..
    Bothell, WA
    Slapped 5 Times in 4 Posts
    I think that your alternator should be enough with a properly wired and designed system.
    Some people use capacitors to minimize the ' light dimming effect ' of a powerful system.
    ..... << Yuh dun know!!
    philip blue02 is offline
    Mar 2011
    Im pretty sure our alts or 100-110 amp. is the Amp a class a/b or class d it can make a difference in the current it draws. But I would think you will be ok with only 400 watt
    SE-R or no? The 2.5's alty will output a few more amps than the 1.8. That being said I have no issues running 1200w worth of amps (1.5 farad cap inline though) and my hids, etc.
    Jan 2012
    A upgraded alternator isn't necessary unless you are running some serious electrical stuff like 1500+ RMS amplifiers.
    A capacitor is just a band-aid to a much bigger problem, the proper way to fix any dimming of the lights is to upgrade the big 3 in your car's charging system and the next step is to either upgrade the battery up front or add a decent cell in the trunk or something.
    And if all of that doesn't work upgrade your alternator to one that puts out about 150 amps or so and make sure the battery can keep up with the alternator's charging abilities.
    Corning, NY
    im with shane. im running a 1000rms kenwood and a 2 farad cap, lights dim, but thats what you have a battery for, your not going to pound it all the way home and not have your car start the next day. end of story.
    white 03 spec v
    For what it's worth, I went through two alternators in 2 years only running a single 400w amp. I was running only 8ga wiring to it, and had the stock battery. After switching to 4ga wiring, adding another 800w amp, the cap, and an Optima Redtop, I haven't had any issues since.
    Jan 2012
    Queens New York
    Quote Originally Posted by shanesauce View Post
    big 3?
    Spring, TX
    You should be fine with a 400watt amp. But it's always good to compensate for extra load on your alternator with an extra dry cell battery or capacitor
    Jan 2012
    Queens New York
    ok cool. ill find a cap. and at some point ill get a redtop battery like misternuts.. lol
    Mar 2011
    [QUOTE=shanesauce;424836]A upgraded alternator isn't necessary unless you are running some serious electrical stuff like 1500+ RMS amplifiers.
    you should upgrade your electrical if your running 1000 rms on a 110 amp alt. Thats only good for around 1100 watts before u add in all your other electrical components
    Jan 2012
    Quote Originally Posted by hannibal View Post
    big 3?
    This is when you upgrade the size of the wiring on the charging system, the alternator to battery wire and the alternator to frame wire are 4 gauge stock and you upgrade these wires to 0 gauge to help out the electrical system.
    Also a better battery is a much better solution to lights dimming than a capacitor is, do some research and you will find out that capacitors just put more load on your alternator.
    Mar 2011
    The redtop is more of a starting battery if your gonna get a optima get the yellow top
  1. QR25DE starter, alternator, maf, ecu and alternator
    By kenc15 in forum Parts for Sale
    Last Post: 12-08-2011, 07:02 AM
  2. Veyron over rated?
    By monkel in forum All Other Nissans
    Last Post: 03-17-2011, 03:40 PM
  3. No power going to amps.
    By dborges23 in forum Audio, Lighting, Alarms, Gauges and misc ICE (In car entertainment)
    Last Post: 01-08-2011, 02:43 PM
  4. Replies: 2
    Last Post: 12-08-2008, 01:00 AM
  5. want to trade amps??
    By Splash45 in forum Parts for Sale
    Last Post: 05-31-2007, 12:04 AM
