Results 1 to 20 of 23
Thread: HID install...
    Sebastian SpecBEE is offline
    Nov 2006
    Slapped 3 Times in 1 Post
    Default HID install...
    hey guys, when u installed ur HID`s, did u remove your headlight housing???
    im doin it later today, so im trying to find any extra advice b4 i start it.. i did my bros altima, and i had to take off the bumper to access the headlights... i know i changed my bulbs in the sentra and i was able to fit the bulb in and out good... but not sure if i need clearance to mount the ballist.... thanks guys..
    Slapped 14 Times in 13 Posts
    Removing the headlight is unnecessary.
    Before you mount the ballasts install the bulbs and roughly calculate where you will mount the ballasts by looking at how long the harnesses are. It's really your choice when it comes to mounting the ballasts.
    Nov 2006
    thanks jon... there should be enough clearance for the bulbs to fit in? or do i have to wiggle my way through? lol
    wigglee it...just a littlebitt..lol
    Quote Originally Posted by SpecBEE View Post
    I fit my hands through all that mess with medium difficulty, you shouldn't have major problems, Take your time, don't crack the bulbs.
    Nov 2006
    yo i just opend the box and found the plastic cap that supposed to be over th eblub, was off and jingle jangling around in the box, think it had any effect on my bulbs?> they look good, and the fillament is not broke or anything... im soo pissed lol
    Nov 2006
    arrite kit came with a set of
    : ballist, blubs, and a wire that plugs into the ballist and into the factory harness... now the pins are red and black, how will i know which pin to attach into the factory harness??? the colors dont match obviously...
    and my high beams wont work right?
    ^^Your high beams wont work, you got that right, unless you got a hi-lo kit.
    You have a multimeter I assume ?
    If you do then it's easy. You know what to do.
    Nov 2006
    guess so lol.. didnt wanna take that bad boy out
    when i had to install my kit i had to take the headlights out because i wasnt able to push the bulb into the headlight housing. I needed to do that to make sure it was secured in the houseing and not move around when i drove the car.
    Nov 2006
    ur kits plug into the harness of the car or it had little pins u have to stick into the harness? i have little pins, and they dont seem to fit in my harness...
    Who did you buy the kit from? It's supposed to have a harness that plugs into your stock one. If not feel free to snip the pins and stick them into your stock harness.
    DO NOT CUT YOUR STOCK HARNESS !!!
    take a picture of the kit, i wanna see how they made it
    ^^Yepp, then we can guide you properly.
    Nov 2006
    yea, i wasnt gonna cut the harness lol, i was gonna snip th epins out an dsplice them into my factory wiring, ill get u a pic when i get my camera at home... im at work..
    Nov 2006
    check out the pic in the page, thats my kit, now look at the harness to the top right of th epic, those two harnesses plug into my cars harness, BUT where u see th eblack harness attachment, i have two metal pins as if u are supposed to stick them into the indivual pin sockets on the harness....
    its for an h13 bulb
    http://cgi.ebay.com/ebaymotors/Xenon...spagenameZWDVW
    Queens
    I installed two kits in my car and never once removed the headlights. Also I am sure your kit is plug and play so like john said please dont cut the harness lol. Should be a 30 min install even for a novice. Good Luck
    09 Mazdaspeed3 = Current
    NOOCH!!!!
    DO NOT even think about splicing wires, don't fokken do it. Call me before you attempt anything like that. You have to use the pins do not splice any wire whatsoever.
    You have my number, I'm in the subway by 6:15pm, call before then or after 7:30pm.
    Baby Kicker
    I'm on a boat
    y do u guys make everything so complicated, hid kit is the easiest thing to do
    Mamut Shift_POLSKA
    Thats how I do...
    www.djtunez.net
    www.247nightlife.com
    Quote Originally Posted by Matts Spec V View Post
    Not if you get a BS, non plug & play kit.
  1. how do you install an HID kit?
    Last Post: 10-28-2007, 10:16 PM
  2. LS install.
    By Blackout-Spec in forum Naturally Aspirated (NA)
    Last Post: 02-22-2007, 12:52 AM
  3. help with HID install
    By Cloud9 in forum Naturally Aspirated (NA)
    Last Post: 12-28-2006, 11:36 PM
  4. My header install
    By Ar6entino in forum Naturally Aspirated (NA)
    Last Post: 02-24-2006, 09:14 AM
  5. cam install
    By soSinSER in forum Naturally Aspirated (NA)
    Last Post: 02-17-2006, 09:56 AM
