Results 1 to 8 of 8
Thread: I NEED HELP!!
    Jan 2007
    massapequa
    Default I NEED HELP!!
    yo whatsup everone....well i put that piece in the o2 sim 2 get the check engine light off....well for 10 miles it was off then it popped back on...but it wasnt for the 02 sensor....the codes were p0037...which was something with bank 1 and 2 and involving heat or something....the other was p0507 which is the idle control valve....what the f**k do i gotta do to get them off?? any1 with help please lemme know a.s.a.p. i need an inspection!!
    thanks to all in advance
    start off by reseting the codes and see if the same code come back on.
    Jun 2008
    Jersey
    you sure you wired the sim right? I put a sim on my 240 before and wired it wrong... got all kinds of wierd error codes. I eventually got rid of it (long story) and did a custom o2 sensor setup to fix my issues.
    djtorello
    Guest
    Quote Originally Posted by silvabullit View Post
    Are your o2 sensors 4 wire or 2 wire?
    Sebastian SpecBEE is offline
    Nov 2006
    Slapped 3 Times in 1 Post
    sounds liku have a bad o2 sensor and a throttle response problem.. its not sitting right at idle... check your TPS throttle position sensor... and make sure if u wired up ur 02 sensor u did it right.. our cars have 2 wires on the sensor.. a white and black... did u bang or drop the sensor?
    Jan 2007
    massapequa
    yeh i was thinkin i had a bad o2 sensor from no cats for a long time or something...maybe its just really dirty....i never dropped it or anything.....when u ask about wiring do you mean how do i have the foulers plugged with the 02 sensor or the wires themselves??
    Jan 2007
    north carolina
    when i had to get my car inspected after moving i just reset my code and my car passed inspection basically right after i got to the dealer i cleared the code they did the inspection and i was out in no time iv had the same code on for like 3 months now system rich bank 1 just ignore it my car has been running the same if not better soooo fock it
    Jan 2007
    massapequa
    gorilla i was thinkin bout trying that but someone was tellin me it wouldnt work....so u basically jus deleted the codes right b4 u went 2 the dealership nd when they ran it threw the computer nothing showed up?? did u disconnect the battery also or jus deleted the codes?? get back 2 me asap thanks
