What is the best pressure # to keep the tires inflated? 17"...
Summer?
Fall?
Winter?
Spring?
Right now all my wheels are between 30 and 31
I keep them at 33psi now. And that should be good year round. But when it snows I lower 2psi
Mamut Shift_POLSKA
Thats how I do...
www.djtunez.net
www.247nightlife.com
well all season long should be 32 or 33psi...if u have lower then 30 then ur car rolling heavier and u waist more gas..and u feel ur tires more mushy. recommended for all tires on a car is 32.
I heard during summer you should lower it, since the tires get so hot from the road...
and for the winter you should raze it . . .
In summer they do heat up much more but I doubt you'd notice the difference unless you drive like a maniac. Nissan tells you what to run on the tag located on the pillar when you open your driver side front door. Doesn't say anything special for varying weather so I'm sure you'll be okay with constant pressures year round.
i usually do 32psi on my car and on the subbies i work on
Ok so I will get it up to 32-33psi probably . . . increase my mpg =]
i usally do 35 psi year round dont no why just like how the car drives like that
2005 code red spec v with K&n typhoon intake, mmi, xs power header race package magnaflow high flow cat magnaflow catback wit 2 14" resonators axxition sts gen 2 24mm stillen front sway bar tein s-techs 03seat swap, tuned afc neo....if only u new what was comming
go to 33psi, you probably wont feel a difference in the drive and might save 1 MPG
it also depends whats your max psi. some tires hold more then others. commen max psi for 17's are 40 or 45.
I am using stock size tires.... the ones that usually come with 17" wheels
anyway i pumped it up to 33psi all around . . . and i felt a slight difference right away =]
Thanks for all the input guys
/thread
if u want the best MPG inflate to 40 psi, some tires can hold max of 50 psi... at 40 psi u feel more bumps though.. stick with 33-35 and ur good
