Okay so I need some help here. Last night I start my car and the throttle wouldnt go up at all..my foot was to the floor and the RPMS wouldnt go up. Turn the car off waited a few minutes and turned it back on. Then it worked again. Check the check engine light and I got '0605' which is "Internal Control Module Read Only Memory (ROM) Error "
Wtf is that?? It happened after I got my tank filled up. I cleared the code and since that time the car was okay.
Any ideas? Wha am I looking at here?
-=Vrooom
P0605 i think is a control module code... if it cleared and didn't come back then you should be fine. the first step in diagnosing a problem is making it happen. If you can't make it happen again the there really isn't a problem, just a momentary malfunction.
ECU wigged out for a second. That's a rare one. Not sure on the details of the code, Ill have to look it up.
2k4spec;u ship my shit?
blk03specv; you ship my shit????
blk03specv; lol but im not black?? lol.. i assume you mean my car haa
2k4spec;yea lol
Well I cleared the code last night, and drove it to work this morning and it was fine..no code. Then got out of work, turned it on and within a minute the check engine light came on again..
:x
-=Vrooom
same code?
Im assuming so..because the normal codes I get turn on when I instantly turn the car on and dont go off til I clear them.
Plus I didnt want to spend 20 minutes trying to get the code again..I was beat :cry:
-=Vrooom
what other codes do u get that are normal ? wasnt there a ecu recall for that foam stuff to stop it from vibrating for 2002 spec ? maybe got a bum ecu or damaged
