has any one tried/done a b15 brembo brake kit on a b16???
if so can u give me the link to that thread would be helpful thanks.....
Why? The stock brakes are already 12.5".....plenty of stopping power....
Sent from my DROID2 GLOBAL using Tapatalk
for non ser and base ser I'm sure it would work just fine, you'd likely need only a spacer for the caliper, even then I doubt it since nissan uses a standard bolt spacing for many of the fwd models. BUT the 07+ SER + Spec V are 5 lug so you'll need new rotors. the SpecV also uses a larger + thicker rotor than the old specV, You could probably shave the pad to regain the extra 2mm needed for clearance but you would 100% need a spacer to step the caliper out enough to clear the oem rotor. If you want to upgrade and not shave the pads, the rotor the REAR rotors from a 350Z brembo would be a good candidate as it's the right size. You'll still need a custom spacer to mount the brembo caliper though.
If your interested in trying let me know. I have a contact and can get the brembos calipers brand new, fully loaded w/ pads for roughly $215ea
