Results 1 to 5 of 5
    Dec 2011
    Default Shifter problems?
    I have a 2007 Nissan Sentra Base. I was putting a new shift knob on and once I got it on I took it for a spin around the block. I noticed when I put it in first i hear a pop. I didnt think anything of it until I realized that the gears were very tricky to find. I cannot find 1st at all now. I have reverse and sometimes it gets stuck in 5th and 6th. Any suggestions? I know that before there was little to know play in the shifter before the pop and now it moves around alot and when it is in gear it the shifter moves as well. It kind of worries me since I just bought it.
    Farmington, ct
    Check with allsentra.com
    Alot more b16 know how on that site
    Although id reccomend poppin off your shifter trim and check the linkage
    Sent from my LG-P506 using Tapatalk
    03 Silver Spec-v
    Bolt-ons, and some N2O
    Dec 2011
    went to nissan and they determined that a piece of plastic in the shifter had broken. Need a whole new shifter.
    check out allsentra.net (mostly 07's and up there) to see if anybody is parting out one...
    Blake W blake293 is offline
    Fort Wayne, IN
    had the same problem. there is a small piece of plastic at the front of the shift boot. check under the boot cover. there is about a 3.5 inch piece of plastic that holds the shift boot on. see if the shift linkages are rubbing. remove excess plastic until smooth shifts.
  1. need help with 2 problems
    By jsk8r57 in forum Troubleshooting and Support
    Last Post: 07-01-2011, 04:25 PM
  2. Problems, Problems, And More Problems
    By SCOOBS in forum Troubleshooting and Support
    Last Post: 06-16-2011, 05:34 PM
  3. Some Problems help someone???
    By burnin714 in forum Troubleshooting and Support
    Last Post: 02-15-2011, 12:25 AM
  4. Problems with FI-R
    By theschrum in forum Member Feedback
    Last Post: 11-04-2010, 02:24 PM
  5. got some problems please help
    By axles03spec in forum Troubleshooting and Support
    Last Post: 09-28-2010, 06:06 PM
