2002 Sentra SER Spec-V
D2 Coilovers
Nismo Short ram intake
DC sport 4-2-1 header
Nismo Exhaust
Nismo Cams
BSR
Knock sensor relocated
Black Extended Lug nuts
AEM wideban
SAFC-II
Gold 02 17'' stockers
Blacked out taillights
10000K headlight hid's
3000K yellow hid w/ Yellow lens fog lights
Optima Yellow top battery
Alpine DOUBLE DIN radio
Soundstream EQ
Pioneer 4 channel amp
Hifonics 1800w amp
1 12'' Kicker L7
Shift_Intimidation
5 lug
megan coilovers
The little Spec that has been revived and given a third chance
Got totalled twice, now she's a beauty.. never had a code, doesn't burn a drop of oil, and she has no airbagslmao.
-Work Emotion CR Kai 18x7.5" +35
-AEM CAI
-Custom full 2.5" exhaust made my me
-RZ Ralco crank pulley
-BSR
-Fidanza lightweight flywheel and stage 1 unsprung clutch
-Energy motor mount inserts
-Throttle body bypass
-world rally blue paintjob!
-It also has enough audio work to mess up your hair when sitting in it
runs 14.4 at 97.9mph, and dynos about 180whp
14.4 @ 97.9mph just bolted
^^ someone didnt read the rules
Mods:
Nismo CAI
Megan Header + midpipe
Apexi WS2 catback
BC Racing Coilovers
skateboard bearing shifter bushings
FI-r soild motor mounts
weighted shift knob
5zigen fno1rc's bronze
Mach 1 lip
5 panel rally mirror
Axxiton STS
thats all i can think of atm
2002 Black Spec-V
-121,xxx on the body, about 78,xxx on the motor
__Exterior___
-02 ebay PU lip
-headlights (10000K hids)
-Yellow fog lights w/ (3000K hids)
-Tinted 02 taillights black
-Red overlay reverse lights
-Gold painted 02 spec-V rims
-D2 coilovers
-Stoptech slotted front rotors
- Hawk brake pads
-Oem rear brake change
-Black extended lug nuts
-15% window tint
-5% rear windshield tint
__Motor__
-Rebuilt tranny
-Nismo Cai --> currently short ram intake w/ clean autozone airfilter ;)
-wrinkle white valve cover
-DC 4-2-1 Header
-Nismo cat-back exhaust
-4G Grounding kit (big 3 mod w/ 5 wires) in red
-Optima yellow top
-NGK spark plugs
-Aem Uego Wideband
-Apexi Safc
__Interior__
-Alpine double din radio
-Soundstream EQ
-Soundstream Tweeters
-6.5 Eminence Mids
-Alpine type R coaxils rear deck
-Alpine 600w 4 channel amp
-Hifonics 1800w monoblock amp
-1 12'' Kicker L7 in kicker box
- Partially gutted trunk
- Gready Rear (trunk) strut bar
-LED interior light
Shift_Intimidation
02 spec v
D2 coilovers
Hotshot header
Rays g-games
Vis carbon fiber hood
Tuned_DE's 02 Spec V
Team N.V
Scrapin:somehow we ran into tuned_de on the highway and him and the bimmer went at it in traffic, that tuned_de mofo is nuts and so was the driver of the bimmer...lmao
2003 GXE
QR25de/ 6 speed swap
KSport Kontrol Pro
Megan Racing Exhaust
17x9 Rota Grids
2004 Brembo Calipers
Low is a Life Style
Mods:
-Treadstone turbo kit tuned w/ UpRev @ 8 psi
-Volcanic ash wrapped down pipe
-2JR Custom 3" Side Exit Exhaust
-Prothane Motor Mounts
-BC Racing Coilovers Track Spec 10K/10K @ 32 clicks
-Negative 3 Degrees Camber in the Front
-Energy Suspension front control arm bushings
-Energy Suspension rear trailing arm bushings
-Greddy front strut tower bar
-Eibach 25mm Front Sway Bar w/ Energy Suspension front sway bar bushings + End Link Bushings
-Eibach 19mm Rear Sway Bar
-Unbalanced Engineering bumpsteer elimination kit
-$5 WHA Washers
-Tanabe 4-Point lower tie bar
-Hawk ceramic front brake pads for Brembos
-Mat Black 17x7 +35 5-Zigen fn01r-c rims
-02/03 Front Bumper Conversion w/o fog lights
-VIS vented carbon fiber hood
-Ultra lightweight battery (13lbs) reolcated to the trunk
-Kirk Racing 6-point roll bar
-Fully gutted car (car weighs about 2350 lbs with roll bar)
-Hayabusa side view mirrors for less drag/better aerodynamics
-Sparco Evo 2 racing seat w/ 5-point Harness
-2JR shifter bushings
-Zietritronix AFR gauge
-Hood spacers
-A/C delete
-Moonroof delete w/ 2JR lexan panel
-Nardi Torino racing steering wheel w/ NRG quick release hub
-JWT BSR
-2JR 10mm spacers + wheel studs all arounn
-TOYO R888 225 tires
2JRacing Project - Respecv1 SER - Lighter, Faster, and More Grip
-DC sports 4-2-1 header catless,
-Greddy EVO 2 catback
-Ebay Short ram intake
-ENKEI bronze 17x7 wheels,
-Eibach Sportlines springs.
-Solid Motor Mounts
-4$ washer mod
-Nokya Yellow Fogs
- Slotted rotors
-Zeitronix Wideband
-Safcii
- Balance shaft chain cut
-Knock relocate
- SS clutch line
- Shifter bushing 2JR
- CF OEM Hood
-Turbo KIT ready for install during winter break.
-Crank Pulley
-RS front lip kit
-STI roof spoiler
Mpls, MN
More details in showoff thread
L8YBUG/03 Spec-VT/Murderapolis
Garrett 60-1 w/ tubular top-mount 300whp on 7psi spring (mustang dyno)
Fully custom fabbed hot and cold side piping
All fabrication done by yours truly (exh, mani, ic piping, alt, etc.)
3" DP and full 3" aluminum exhaust
TiAL 38mm MV-S wastegate
TiAL Q 50mm BOV
Fuel Injector Clinic 900cc's
AEM FI-C w/ E85 tune
Walbro 255 return setup w/ AEM fpr
Custom built center bin gauge pod
ARP Headstuds
Ajusa headgasket
Greddy Profec B-Spec II boost controller
BSR
Fidanza Flywheel
Competition Stg 3 clutch
NX Intercooler Sprayer
VIS cf hood
Battery/Alternator relocate
------MOD LIST------
Knock Sensor Relocate
TB Bypass
Idle Raised
Timing Advance
MMIs
TB Spacer
Nismo Intake
DC Headers
Megan Cat Back Mated to an Apex-i WS2
Lightweight Crank Pulley
Fidanza Lightweight Flywheel
Clutchmasters FX100 Clutch
Rev-Auto Torque Damper
ebay Oil Catch Can
Tien S-Techs
Innovate LC-1
Apex-i SAFC-II
VIS Carbon Fiber Hood
Nismo Style Carbon Fiber Lip
Benen Tow Hook
cf hood n trunk
Custom red paint
Fn01rc 5zigen
I/h/e
Supercharge (soon)
D2 suspension
Nismo front sway bar n rear..
rs lip, rear nismo lip (genuine)
Evo 8 seats, takata harneses
Convert 04 to 03 and many more...
