*aluminum
with the swap can you run dual exhaust on a 02 se-r
yea the driver side has the evap thing where the muffler would go.
hey guys I was going to go turbo but decided to do a vq sqap instead. Does anyone know a websitE where I can actually order a engine and all the parts I will need to do the swap. I had a website for a guy who didi the swaps but lost his info
engine...just find a good one at a junk yard, not sure if car-part.com has some or not but check it out.
there are pleanty of threads out there that has all the parts you need (look in the vq section)
trav4011 makes a diy kit
The Nissan Family...
02 Spec VQ (11.97@115 http://www.youtube.com/watch?v=xRkKUBbFzs8)
05 Altima SE-R (dd)
95 240 (610whp SR powa'd http://youtu.be/ToH7FyHvS2E)
05 Armada LE (the wife's)
04 Spec V
NISMO catback exhaust
NISMO CAI converted into SRI
SRS Racing Header
BS chain cut
Short shifter
CORNDOG: My spec has Vtec........ Maybe u guys didnt purchase that option????
Im not sure how well I would drive with Joe up my ass for all those laps
05 Blackout Spec V _____________Willwood BBK
Stromung Exhaust______________Eibach Pro Springs/Anti Roll
Pioneer Nav___2J Shifter Bushings___2J ALK____ AEM CAI
Boston Acoustic Highs/Mids[/color]____Nismo Sway Bar---XS Header
JL Amps/Subs_______Jimmy Bar______ VQ Swap To Come?
04 Spec V
SRS Racing Header
BS chain cut
Short shifter
Im definatly thinking about doing this if my QR blows up. Just because its the logical choice....
Does it matter what Vq you go with? Cause i can pick up an VQ out of an 08 or newer maxima(290hp) for $1375 with 60,000mi on it.
If you choose that motor your going into uncharted territory travis uses an 04-08 motor in his swaps, so the wiring would be much different with thay when being said i know he planned on doing a 7th gen swap so you may wana try and get ahold of him ...good luck
