I'm working hard to finish this soon!
i think the 07 max aint gunna work ... 02-06 will... also headers with work but i think u need a custom ypipe to fit....also when u get the motor just change the rear valve cover to a 04-06 vavle cover(if u get a 02-03 motor) so u wont have it leak on u( known problem) and might as well change the pistion rings cuz their known to be shit and to cause it to burn oil lol...
Project on hold. Shit happened.
http://www.b15u.com/f***-my-life-lov...-very-sad.html
Just FYI, you can have Nigel from STP do the wiring harness for you, I believe the price was around $500.
Travis also sells the mounting kit for $600 or so.
That's probably the two hardest parts of the swap if you don't have the knowledge or tools.
mounts and axle bracket are easy... the wiring is a btch i would like staytuner do it.
What makes the wiring hard to do?
time and patients i dont have lol....... even if the wiring is done u would need to program the key again to the immu and ecu....... which is no big deal just take it to nissan or some one that can do it.
u have 5 lugs ???? nice i want to see a spec-v with 350z rims lol
nice nice i mean these
http://i25.tinypic.com/8xo56x.jpg
Holy shit that looks tight!
2001 Nissan Sentra SE 5spd w/PP
2006 GTO 6spd, 18s
2009 Yamaha R6
Thanks!
Today I'm having fun reading through the 03 Max and 02 Sentra FSM.
Page EC-1306 and EC-1307 of my Sentra FSM were playing with my mind. They're duplicates.
So anyway my thinking right now is "3L" ECM plugs into old Spec-V plug.
New Maxima engine harness will splice in or plug in to old harness.
Wires in the wrong positions will be cut near the ECM and moved.
Starting a spread sheet to compare wires and values.
http://mysite.verizon.net/vze7erz1/id1.html#tsdmod
i think all u have to modify is the plugs that go under the dash IDK.... BUT I AM HAVING NIGEL do my harness to save the hassle....just save a lil more money and have some one with experience in the harness to do it because u might just waste ur time trying to figure it out.... mounting the engine is easy... wiring is a pain
Yeah I've been thinking about it now... engine harness will be VQ & ECM VQ, nothing to change there... then there's gauges... and I'm thinking of swaping out for as set VQ Altima or Max... then there's A/C and cruise and I think they're going in the trash...
I was wondering about the drivers side mount for a while, but I spent some time looking at other swap pics and realized it was just the stock sentra mount ....
I sure dug up a lot of pics in last few days.![]()
Last edited by 5er; 07-03-2010 at 01:11 AM. Reason: drivers side... not passenger oops!
my ac is going to work.. i used a 04 maxima mount passenger side mount.
i made a thread on the vq swap already fyi.... i even include install instruction
Hey guys! I didn't expect this but I got a response to my Craigslist advertisement for parts wanted today!....
"Hi. I have an engine/auto trans from a 2003 Maxima SE. I also have the ignition, engine harness and MAF. The car was totaled in 2004 and had only 13000km on it. Give me a call and we can discuss price."
FYI that is about 8,000 miles.
Unless it's free, I'd rather get and ignition from a NATS car with the "3L" ECM already program matched.
I can't do anything with the transmission.
I need some advice now.... What do you think is a good price for the engine / harness and MAF? And if this has been sitting since 2004 is it any good?
Ok soooooo... he won't go below $500.... and he wants me to take everything (engine has all accessories). Going to check it all out probably tommorrow.... he says he has the dash and a bunch of the car left... I think I have to take the Doors LMFAOFF! Thats the good.... the bad.... the engine has been sitting in storage for 6 years. I'll see if I can spin the crank ( is this a good idea?????) Lower oil pan cracked and 1 valve cover cracked.
Opinions very welcome!!!
Some research shows this deal is not too bad.
Courtesy Nissan
Lower Oil Pan $130
Valve cover $104
If I get $734 for the tranny, I think I can, I have the rest for free!
i got my engine from car-part.com lol i put nearest distance and a local yard had one with everything alt/ac pump/ auto wiring harness everything $800 67k miles ..![]()
