Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 110
  1. #21
    Karl MisterNuts is online now
    Quote Originally Posted by alex_b13 View Post
    i know it gains power. but finish first the project than do what he like.
    Probably stating the obvious, but meth only gains power through tuning. I've seen an SR20DET S13 lose power with a meth kit before tuning.
  2. #22
    Jun 2010
    i agree.
  3. #23
    Peter shortcut10 is offline
    Meriden, CT
    Well yea of course, the motor has got to be complete and in the car, I'm just talking as far as another tuning tool, meth gives you the capability to keep the timing advanced more than you would normally be able to, so it helps as far as a tuning and drivability tool, I've never seen a car lose power with meth unless it wasn't tuned properly or the kit was just bolted on without adjusting the mixture, you can't put straight meth into it that will make you loose some power you need to mix it usually 40%meth 60%water. Meth to help with pre-detonation, and efficient burning, along with cleaning the carbon from the chambers and intake; while the Water keeps the charge temps down, and when it's the combustion chamber the single oxygen molecule seperates under pressure and combustion allowing for a cooler chamber temp and also a larger(not by much) explosion in the chamber which in turn means more power =)
  4. #24
    Supporting Vendor
    Oct 2008
    I have a very good understanding of how methanol/water plays a part in the suppresion of detonation, and, cooling, due to it's high heat latency.
    Running water/meth many increase power slightly due to the ability to run a more aggresive timing curve, and we might end up trying it. However, I don't think we'll see huge gains that make it worth the effort/risk of pump failure/nozzle clogging. If a tune is based on a properly working meth/water injection system, and that system falters, then, you put the engine at risk. In this case, meth/water injection might yield another 5-6whp through more aggresive timing, but, to me, it's not really worth the money/risk.
    I've used meth on turbo/non-intercooled vehicles with great success, but, I'm always concerned about a system failure, or nozzle getting clogged. IMO, it's just one more thing to worry about. But, it DOES work..
    Quote Originally Posted by shortcut10 View Post
    www.fi-r.net
    985-791-1826
    Nissan Performance
  5. #25
    Jun 2010
    E85
  6. #26
    been a couple weeks, done yet?
  7. #27
    Supporting Vendor
    Oct 2008
    Update...
    Short block is finished/assembled at the machine shop..
    Cylinder head is at the head shop, and I just got a set of cam caps from Jesse (owner) late last week. It looks like he mixed up the big cap on the end with another head that he had over there.. and it didn't match up properly. The caps are machined specifically to each head. Fortunately, I have a few caps here, and it looks like one will work fine with just a line hone. So, that'll be wrapped up this week. Springs arrived and will go in with new valve stem seals. Head will be surfaced, hot tanked, and prepped for installation, as well.
    So, a minor setback, but, nothing serious..
    www.fi-r.net
    985-791-1826
    Nissan Performance
  8. #28
    Bob smokeyV is offline
    New York
    Quote Originally Posted by B15Paper02 View Post
    lol
  9. #29
    Quote Originally Posted by smokeyV View Post
    lol
    What? just wanted an update since it is close to completion
  10. #30
    Supporting Vendor
    Oct 2008
    I should have assembled pics next week..
    www.fi-r.net
    985-791-1826
    Nissan Performance
  11. #31
    Jan 2007
    massapequa
    i cant wait to see the numbers put down with this motor....
  12. #32
    Supporting Vendor
    Oct 2008
    Lost a full week.. I was sick with the flu, so, I'm a week behind. The short block is ready to go at the machine shop.. I'm just waiting for my buddy to get back with his truck so we can go get it on Friday. Otherwise, it would have been finished last week.
    Pic of the exhaust side while in the middle of working on it a few weeks ago.. (forgot to upload it)
    Got the head back today from the head shop.. Came out awesome.. Nice and clean, with a shaved seating surface (was warped .002-.003"), and ready to install on the short block. I'll have that back on Friday, and I'll have pics up during the day.
    Finally coming together, and we'll start working on the custom long tube header with 3" collector, along with the custom ITB's.
    www.fi-r.net
    985-791-1826
    Nissan Performance
  13. #33
    Supporting Vendor
    Oct 2008
    BAM!! Got the parts back late last night.. block and crank are all machined/clean, and ready to go. I spent last night/the entire day today putting this together.
    So fresh and so clean, clean.. New bearings installed..
    Crank installed, new 07+ main bolts installed..
    Oil support rail, under the oil scraper ring.. Whenever the pin boss intersects the oil ring groove, it's a good idea to run a set of rails to support the rings in this void. Gives better oil control..
    Goodies..
    Double checking the machine shop's ring gap setting.. Never hurts to check.. .020" on this top compression ring (stainless.. btw..)
    A cheap ring expander can save your fingers (and your rings from snapping/bending)
    Nice dab of Lubriplate assembly grease..
    Pistons/rods installed.. ready for the head to go on..
    It's not bolted down yet.. Just tossed it on for a pic. I'm missing the two dowel pins that align the head to the block. I have a set ordered for next week.
    The final piston to wall clearance was left a little on the loose side (.005") and we set the ring gap a tad loose (.020"/.022") as well. This will allow Jesse to spray a big shot of nitrous if he ever chooses to do so. It'll make for a little more piston noise, but, it's safer than going too tight and allowing a piston to catch the wall/scuff.
    All critical clearances are as follows:
    Piston to wall (as set by machine shop):
    1- .0052"
    2- .0050"
    3- .0053
    4- .0051"
    Ring gap (set by machine shop, and double checked by me):
    1- .019"/.021"
    2- .020"/.022"
    3- .020"/.021"
    4- .020"/.022"
    Crankshaft end play (thrust washer clearance)- .007"
    Crank shaft runout- .0005"
    Rod bearing to journal clearance:
    1- .0025"
    2- .0023"
    3- .0026"
    4- .0026"
    Main bearing to journal clearance:
    1- .001"
    2- .0012"
    3- .0011"
    4- .0012"
    Piston pin to pin boss (set by machine shop)- .0005" (all 4)
    Piston pin to rod bushing (Small end) (set by machine shop)- .0005" (all 4)
    Rod big end side clearance (space between the side of the rod and the crank pin)- .008" (all 4)
    I'm pooped.. going drink a few beers and enjoy my weekend..
    www.fi-r.net
    985-791-1826
    Nissan Performance
  14. #34
    steven stevensspecv is offline
    lusby, md
    dam thats looking real fresh cant wait to its all together, i bet jesse is getting real excited
    Fully Bolted.stock clutch and flywheel, stock bottom end. 04 SPECV
    Thanks to TDM Imports, Midatlanticsentras and 2J Racing.
    12.44 107.33MPH 1.6 60 FOOT
    05 altima 2.5s dd
  15. #35
    Supporting Vendor
    Oct 2008
    Jesse hasn't even seen it yet.. lol..
    www.fi-r.net
    985-791-1826
    Nissan Performance
  16. #36
    Ottley Scrapin is online now
    nice work man!
  17. #37
    Ashwin ash is online now
    nice! can't wait to see this completed...
  18. #38
    Supporting Vendor
    Oct 2008
    Engine will be complete this week, and then it's on to the ITB's and header.
    www.fi-r.net
    985-791-1826
    Nissan Performance
  19. #39
    Dec 2008
    I'm confused. Are you going to have ITBs close to the head going into runners->collector->filter or what?
    the only ITB's I've ever seen were open-air (no filter, no tubes,etc)
  20. #40
    Jay Lane jayjaya29 is offline
    Oct 2008
    Ithaca, NY
    Subscribed!
  1. VQ35DE Nate's fully built/8200rpm N/A VQ Spec V..
    By Trav4011 in forum Engine Swaps, Builds
    Last Post: 07-13-2011, 09:19 PM
  2. FS: Fully built QR25DE Turbo Ready Engine
    By Rican915 in forum Parts for Sale
    Last Post: 07-29-2010, 04:30 PM
  3. Jonnykoomz /fully shaved 02 SER / nnj
    By jonnykoomz in forum Member Rides and Project Cars
    Last Post: 07-18-2010, 08:45 AM
  4. What does FULLY BOLTED mean to you?
    By SpecBEE in forum B15 Sentra (2000 - 2006)
    Last Post: 10-07-2009, 11:15 AM
  5. Parting out a fully bolted Spec V
    By 03blackout in forum Parts for Sale
    Last Post: 08-21-2007, 09:14 AM
