Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 110
    Supporting Vendor
    Oct 2008
    Default Jesse's fully built N/A QR..
    I've been working on Jesse's QR project for a while, and it looks like I'll finally have the bottom end back from the machine shop next week..
    I am finishing up the cylinder head this week..
    Here's a few shots from yesterday.. reworking the combustion chambers.. unshrouding the valves as much as possible, and removing the ridge at the entry into the chamber, around each valve.
    Chambers finished, and polished.. You can also see the bowl work from this angle..
    Intake runners finished with 220 grit, then, hit with a buffing wheel to clean up..
    The head will be topped off with JWT springs, and C1 camshafts.
    The bottom end has 11:1 C/R forged pistons, Billet I beam rods, and a lightened/prepped early model QR crank.
    We will either be running a sheet metal intake manifold with 3" TB and CAI, or possibly a custom set of ITB's. The engine will also recieve a custom, tuned length header, with a 3" merge collector, and full 3" exhaust. We plan on spinning it to a reasonble 7500rpm, and hopefully making somewhere in the 210-220whp range. Maybe more..
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Supporting Vendor
    Oct 2008
    BTW.. 2 days of porting.. about 4 hours per day.. my hands are HURTING! lol..
    www.fi-r.net
    985-791-1826
    Nissan Performance
    when do you plan on completing this build? I keep reading that the QR head only needs minor porting (motoiq)...
    steven stevensspecv is offline
    lusby, md
    thats whats up that head looks real, good, cant wait to see it all done
    Fully Bolted.stock clutch and flywheel, stock bottom end. 04 SPECV
    Thanks to TDM Imports, Midatlanticsentras and 2J Racing.
    12.44 107.33MPH 1.6 60 FOOT
    02 ser auto my dd
    05 altima 2.5s wifes dd
    Jun 2010
    nice hope to see this run
    Yeah I didn't think our engines needed an extensive port job either, only way to know would be to flow bench before and after on the job. If you took too much out will affect the velocity... Oh well either way hope to see it running, why has it taken 2 years? If that's what others are referrin to?
    Aug 2009
    Slapped 2 Times in 2 Posts
    wow that looks real good. nice job travis.
    btw, i read the tags at the bottom... wow... fuckin haters...
    Supporting Vendor
    Oct 2008
    Quote Originally Posted by B15Paper02 View Post
    There's a difference between spending time to optimize the runner and combustion chamber shape, and just going in and hogging out the ports. Trust me.. I know what I'm doing.. I built a 9K rpm head for a destroked QR, that actually made power all the way out to the limiter, and would have made more had we kept going. I also built a set of heads for Barry's VQ, which ran 12.29 @ 110.82mph with a stock intake manifold and C8 cams.
    The QR head flow well, but, has room for improvement with tons of sharp edges and room in the chamber for reshaping to unshroud the valves. Casting flash can be removed as well. Just small changes here and there make for decent gains. But, the work is tedious.. We will flow the head when it's at the head shop getting cleaned/assembled.. just like any other ported head that I've built.
    It hasn't taken 2 years.. I already explained this below, in another post.. I won't explain it again.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    damn what's up w/ all the hate...the owner is content w/ the time frame, i don't understand why everyone else gives a shit...
    can't wait to see this completed
    Jan 2007
    massapequa
    mann why are so many ppl hating.....yo trav dnt pay attention 2 ppl bashin you u do great work n ppl gotta understand great work takes time...do it once and do it right that way u dnt gotta do it again....cant wait to see the hp #s
    Supporting Vendor
    Oct 2008
    Anyway.. back on topic..
    The head is now at the machine shop for a cleaning, flow bench testing, and getting shaved a hair to cleanup.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Supporting Vendor
    Oct 2008
    Short block is being machined this week/early next at the machine shop..
    Head is at the other shop (head shop). I should have everything back next week.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Sebastian QR25DE_SpecV is offline
    Jun 2010
    Austin, TX
    No secondary injection?
    Supporting Vendor
    Oct 2008
    Quote Originally Posted by QR25DE_SpecV View Post
    What for?
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Jun 2010
    Austin, TX
    What for?
    Moarr pooowwwaaaahhhh
    Jun 2010
    why not get bigger injectors.
    Peter shortcut10 is offline
    Meriden, CT
    Or try meth on the N/A, to keep overall temps down, and minimize chances of detonation
    Jun 2010
    travis is using 11:1 C/R forged pistons i don't think it needs meth injection or secondary injection, unless the owner decides he wants 13:1 or higher than maybe. i think 93 should do it with slightly bigger injectors and a good timing and fuel tune for 11:1.
    Meriden, CT
    Meth isn't only for high compression or Forced Induction, Google it, people run it on Mustangs, Vipers, some N/A Hondas, plus more, and there's even some one who put it on a N/A VQ Maxima with good gains thanks to it
    Jun 2010
    Quote Originally Posted by shortcut10 View Post
    i know it gains power. but finish first the project than do what he like.
  1. VQ35DE Nate's fully built/8200rpm N/A VQ Spec V..
    By Trav4011 in forum Engine Swaps, Builds
    Last Post: 07-13-2011, 08:19 PM
  2. FS: Fully built QR25DE Turbo Ready Engine
    By Rican915 in forum Parts for Sale
    Last Post: 07-29-2010, 03:30 PM
  3. Jonnykoomz /fully shaved 02 SER / nnj
    By jonnykoomz in forum Member Rides and Project Cars
    Last Post: 07-18-2010, 07:45 AM
  4. What does FULLY BOLTED mean to you?
    By SpecBEE in forum B15 Sentra (2000 - 2006)
    Last Post: 10-07-2009, 10:15 AM
  5. Parting out a fully bolted Spec V
    By 03blackout in forum Parts for Sale
    Last Post: 08-21-2007, 08:14 AM
