All content is copyrighted and the property of TwoFiveTuning.com. Redistribution in part or whole is allowed, so long as the content is not; altered in a way to be presented or misrepresented as the effort or property of a person or entity other than TwoFiveTuning.com, or for personal gains. In simple terms, don't be a dick.
In the spirit of looking for a good solution in the OEM parts bin I picked up a few of the new pistons to do a little research, a 2008 Rogue, 2009 Altima, and a 2008 Spec V piston, which has a 10.5:1 compression ratio. I also ordered a 2005 Frontier piston hoping the truck motor chassis specific piston might have some unique and worthy features, but, they are on backorder without a release date, so no go for now. I’d also like to see a piston for a Canadian X-trail just for good measure. Before I started this research project I was fairly sure the new QR pistons would share a lot of the same features as the pistons in the VQ35HR and well as some carryover features from the old pistons. Very little made its way from the old pistons to the new pistons, just the anti-friction coating on the skirts and the hard anodizing on the first ring groove, other than that it’s a whole new design. It shares just about every feature of the VQ35HR piston, it’s a nice direction for Nissan and has a lot of features that were previously only found in race pistons.
One of the first things you’ll notice is an asymmetrical skirt design, tapered skirts, and a box type perimeter support.
(bottom view of piston showing perimeter box frame and asymmetrical skirts)
The minor thrust side of the piston, the exhaust side, has a smaller area than the intake side. The intake side is the major thrust side and has more surface area because it is more stressed with side loads, and the decrease in the surface area of both skirts results in a reduction of friction netting better overall efficiency. The direction of rotation of the crankshaft and the angle of the connecting rod pushes the piston into the cylinder wall as part of getting it to go up the bore. The greater the rod angle (like the QR) the greater the side loading force. The coating on the skirts is (most likely) a high quality molybdenum disulphide based epoxy. It greatly increases the wear life of the pistons and provides a lower coefficient of friction and higher efficiency overall, and combined with the skirt design, you get the idea. Nissan has been using low tension thin compression rings for a while now. One of the greatest areas of frictional losses in a motor is the rings. Nissan put together a winning package with the attention to detail given to the design of this piston.
(tapered skirts, larger exhaust side (thrust side) on left, smaller intake skirt on right, note anti-friction coatings, hard anodizing around first ringland, and oil jet notch on exhaust skirt)
The box type perimeter support is integrated into the pin boss for extra support of the pinboss, piston skirts, and piston head. The box runs squarely through the middle of the pinboss and uses gentle radii to avoid stress points and seamlessly merge together for a very ridged support structure.
(detail of boss and skirt structures)
The pin bosses themselves are a strut type with gentle outward sloping sides to widen the base, providing better support, and narrow as they near the pin to save weight. Contoured pin bosses for weight savings are an expensive option on custom aftermarket pistons. The Spec V specific piston has further contouring on the outboard side of the pin boss for additional weight savings. It’s probably a good time to mention the Spec V Gen II QR has a factory redline around 7000rpms, so weight savings is paramount. If I had money to throw away, I'd cut the pistons in half right through the face and take pictures to get a good look at the cross sections and thickness of the piston heads. A good cross section can tell you a lot about structure and the potential of a part to withstand abuse and heat. Maybe, just maybe, curiosity gets the better of me sometimes.
(pin boss detail showing Spec V specific piston profiling (on left) vs. Rogue piston (on right))
(note lack of profiling on aftermarket piston, piston on right is a Gen I QR piston)
Lacking from the pin bosses are the bottom oiling holes of the Gen I pistons.
(Gen I piston oiling bottom oiling holes)
My best guess is it would weaken the thin structure of the bosses, and with oil jets a feature on the new QRs, totally unnecessary for good pin oiling. Notice the subtle cut out to clear the oil jets.
(detail of oil jet (squirter) cutout in skirt)
The ring lands are an area of concern for turbocharged QRs. Nissan follows suit with most OEMs by pushing the top ring up high on the piston to reduce emissions and make more power. As the ring goes up, the ring land gets thinner. It just spells disaster if you run into detonation with a turbo charged QR. The ringland likes to fracture freeing up little sections which bounce around in the combustion chamber, and then bang their way though your turbo’s turbine on it’s way to piston heaven. I was hoping the Rogue piston, being for a truck and heavy duty use, would utilize a thicker top ring land, but that's just not the case. I do feel the alloy and casting quality adds considerable strength in the ringland area. The Spec V 10.5:1 piston's ringland is 1mm thicker than the Rogue or Altima piston. For the picture below I placed a wrist pin between the two pistons to line them up for a good comparison shot.
(ringland detail, Spec V piston on left, Rogue piston on right. Note 1mm thicker ring land on Spec V piston. Also note the very thin ring land for the oil control rings)
The FSM (Field Service Manual) shows the new QRs advancing the intake cam via the CVVT unit in the 40 degree range. The old CVVT sprockets will only do about 33* total, but in data logging I've never seen a value higher than about 23* of cam advance on Gen I motors. As you advance the intake cam the intake valve opens sooner and sooner, that puts it closer and closer to the piston in doing so. The intake valve reliefs on the new pistons are substantially deeper than on the Gen I pistons to allow for this.
(Gen II Spec V piston on left, Rogue on Right, valve relief depth is the same, the difference in the width of the outer rim and the taper angle into the dish of the piston creates the differing shapes of the cutout)
(Gen I piston for reference)
