Page 3 of 15 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 281
Like Tree4Likes
Thread: Qr 25 ITBs
  1. #41
    Supporting Vendor
    Oct 2008
    As far as the IAT sensor.. you can use one from a 2000/2001 SE. It was seperate from the MAF for that model year, and mounts in the intake tube with a rubber grommet.
    www.fi-r.net
    985-791-1826
    Nissan Performance
  2. #42
    this is one of the air box if you need to run the MAF
    [IMG]file:///C:/DOCUME%7E1/MARKPE%7E1/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
    and there will be more ??????????
  3. #43
    Peter shortcut10 is offline
    Meriden, CT
    Question, now wouldn't it be easier just to use the MAF that comes with the QR, because to my knowledge the Intake Air Temp sensor is integrated in the MAF, atleast mine is(22680-8J000), I'm almost sure the 04-06 is aswell(22680-7S000 every Nissan model now uses this number), because I tried to install a 00 Maxima MAF on my car when my MAF took a crap(it was the cheapest alternative and I had one in stock) and the car ran fine the only code I had was for IAT sensor....which I know came seperately on the 3.0s it was attached to part of the intake tube or on a resonator somewhere (I forgot exactly where) so that would take care of that.
    As far as the TPS I know it's attached to an electrical motor.... either way I think the TPS would be the only real issue
  4. #44
    I found time today to play with this set up and i will post picks soon
    i have the runner's for the intake in hand i will be of to the water jet cutter to get my parts cut then into the fab shop to start welding
  5. #45
    If all is well and i do not get to meny guys come to the shop today the first pics will be here to show what i am doing with this project
  6. #46
    Armin pituala is offline
    Ft.Lauderdale
    And finally...pics!
    '85 Supra Black 1JZ-GTE
    520rwhp /417rwtq @17psi on pump gas
    '02 Spec V Blackout 2.02 60', 13.14 @ 105.48 (RIP Spec Weed 8/14/04)
  7. #47
    Ft.Lauderdale
    So what do ya'll think....the air horns are actually longer the ones we're using but we had them laying around and used them for photo purposes only.
    Opinions?
  8. #48
    Dec 2008
    wow. looks badass! Will all that fit under the hood?
  9. #49
    Ft.Lauderdale
    Quote Originally Posted by pimpsmurf View Post
    Yes....two things to consider are the air horns will be about half that length...and the air box comes full size as pictured when we receive them....this box will be trimmed down once we have a test car to get some measurements from.
    So then you like? We got the intake made this week and we put it together this evening for pics. Fitment at this stage is near perfect...just a little more fine tuning in fitment and that part is done!
  10. #50
    Jeremy jeremy is offline
    calipornia
    Nvm. Looks good... what size are u using?
  11. #51
    Ft.Lauderdale
    Quote Originally Posted by jeremy View Post
    Quote Originally Posted by bug man nrg View Post
    We do the R&d for all make of cars the price will be around the Honda set up. there will be two kit .the cheap kit will have a DCOE style body and the next kit will be a SF style body
    This kit will come with the parts in this list
    1 manifold
    1 set of throttle body's
    4 air horns
    1 TPS
    1 linkage kit
    1 backing plate
    1 air filter or air box
    1 fuel rail kit
    nuts bolts and seals
    you will have to get your injectors that you need
  12. #52
    Ft.Lauderdale
    Doh you edited on me....that will be revealed at a later date
  13. #53
    Quote Originally Posted by pituala View Post
    And finally...pics!
    Thanks Armin for taking the pics ,
    so what do you QR guys think ?
    some feedbacks , opinionns now that there is an offical ITB kit ?
  14. #54
    Germany
    Shoot me a PM..... I want to put these in the magazine!!
  15. #55
    BIG AL cupit867 is offline
    QNZ
    That is a very nice set up & very sexy I'll keep that in mind if I decide to go standalone for 2011. I would really hate to loose my cruise control.
    CATCH ME IF U CAN
  16. #56
    Dec 2008
    Please forgive me sirs, but I don't get why this would be wanted for FI over a more conventional custom manifold. I get for N/A if you have standalone and don't need the MAF anymore, but I don't get how the ITBs work better than an aftermarket manifold when you put that carbon manifold and 3" intake (for the MAF) on it.
  17. #57
    Ft.Lauderdale
    The carbon fiber one is for the NA guys just so we're clear. The FI guys would have an aluminum boostbox, the inlet can be whatever size tubing you are using for your intercooler piping....preferably larger on the intercooler outlet side. Throttle response and power at higher rpms are greatly increased due to the velocity stack and tapered bores. Fuel atomization is also greatly increased by pulling the injectors back away from the head. Look at any Ferrari, LeMans cars, and many more boosted or NA high performance race cars use them. They're proven technology especially when the correct side runners and tb's are used.
  18. #58
    this kit will be 48mm or 52mm taper. This is not the cheap kit i will do that one next week if i get the time to mock it up
  19. #59
    Nice that ITB kit is coming along nicely. Next week I'm up to retune and post new results on the VQ35DE ITB kit Should post nice gains with the real 3 in exhaust and new header setup.
  20. #60
    Gti-r Pulsar , Rb26DETT , Audi been using boost and itbs for years, its nothing new
    and there is a differnt plenum for boost apps.
