nice detailed pics. ok the indentations (is there a name for that?) which are obviously to help reduce weight, how they have them on diff parts of the rods are interesting.
Some interesting notes:
1. Crower rod bolts appear to be a few mm longer for whatever reason
2. Crower has more support ribbing on the crank side
3. K1 has a slightly wider area where thecrank end transitions into the rod
4. Crower is slightly wider on the straight portion
5. K1 has 2 oil holes pointing down vs Crower has 1 pointing straight up
6. As far as thickness goes they appear to be more or less equal
dont forget retail prices. and as far as the oil holes go, do you know how it is on the stock rods?
definite +
ditto
HUGE difference isn't it. You had the holes lined up perfectly, right? That is a big plus for those K1 rods. I really thought it would have been the other way around (ie, check the shoulders on the 07 rods vs stock rods. huge difference as well.) It's not just how tall they are but how wide the support goes out to the sides. That's a huge difference, although they are certainly both sick rods.
Also backwards from what I expected. I expected the K1 to be wider but I think because of the crower's wider "neck" it can have it's smaller "shoulder" as above. Plus Crower rods are forged are they not?
This is a big deal as well. the b15 rod used the same (large) hole on the top of the rod to get oil directly onto the pin but it just comes from environment. Inside of these engines are a torret of oil and at 90* B/A TDC it can catch a good bit of oil in that big ass hole.
The K1 rods are way more modern, just like the b16 rods, which have the oil supplies for the wrist pins coming from the high pressure oil rail. That's definitely a more pro way of doing things. This is a huge + to the K1's as well.
These are the two tests that will help a ton in comparison. Weight them (gram scale, not a post office scale) and do a submersion test. Depending on metal comp, the weights and volume could be dramatically different (ie, the K1's are probably lighter, but I expect the K1 would displace more water.)
Obviously we won't destroy two of those suckers, but I would also bet the Crower wouldn't snap as quickly when stretched. Max G load on the piston (and thus the rod) is at TDC on the exhaust stroke. I expect that the i beam is stronger in that respect, however I doubt anyone will be pushing a b15 or even b16 crank to the rpms needed to cause rod failure for either of those so it's purely academic/bragging rights at that point right?
One thing to note is Crower has the specs and can custom build any rod for you with those dimensions. If you want a set of forged titanium rods they can hook you up. haha. I don't know about K1.
my K1 rods are being custom made to custom spec for a Destroked QR for 600 bucks a set.................
I bet the side ribbing on the Crowers also play into the slimmer shoulder.
I wonder if the crower design would allow for the oiling holes further down, on the k1 the rod is angled inward vs straight down in Crower's case.This is a big deal as well. the b15 rod used the same (large) hole on the top of the rod to get oil directly onto the pin but it just comes from environment. Inside of these engines are a torret of oil and at 90* B/A TDC it can catch a good bit of oil in that big ass hole.
THe postal scale was actually pretty accurate. I was looking at the k1 box(probably should have done that orginally) and it said 527.9 gramsThese are the two tests that will help a ton in comparison. Weight them (gram scale, not a post office scale) and do a submersion test. Depending on metal comp, the weights and volume could be dramatically different (ie, the K1's are probably lighter, but I expect the K1 would displace more water.)
FIXED. Added a few more periods for you. I never said they didn't. I say I didn't know if they did.
They are just beef right there where the K1 relys on the shoulders. Most power is like 20*ATDC or so right? so those shoulders are super important for holding power.
I'm confused by what you are talking about.
sweet. so what is the weight difference? I can't find the damned crower weight anywhere
My Crowers are 574 grams 406 186 tot rot recip
so what do the second set of numbers mean, if you can possibly break it down for me.
k1 seems to be a bit thicker in the pics
click to visit 2JRacing webpage" href="http://www.2j-racing.com" target="_blank">click to visit 2JRacing webpage
