Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
Like Tree2Likes
Thread: Engine for my spec
  1. #41
    Dan dpedraza is offline
    Kinda makes me wanna buy an 01 and do an sr20vet
    02 Spec V - I/H/E FX35 retrofit
    "it's better to live on your feet than to die on your knees."
    http://www.flickr.com/photos/danpedraza/
    " href="http://www.fuelly.com/driver/dpedraza/sentra" target="_blank">
  2. #42
    Kris slyguy700 is offline
    Tacoma, wa
    Update:
    Head back about a week ago, and given back to the guy thats assembling motor.
    Engine bay paint purchased (127 for 6 cans of paint!)
    Got vipec in hand now.
    Motor should be compete within a week.
    Spec-v tranny arrived.
    Fmic kit arrived
    s14 t28 (blown) arrived (for t04 compressor housing on gtir turbo)
    Acquiring 17x8 5zigens with dunlop direza's on them. Powdercoated black.
    Z brakes probably going to go on the car.
    Still need:
    P12 bellhousing
    Axle bracket
    Clutch/flywheel (may use a clutch I have laying around from scottys car)
    Wiring solved. Going to try to get it to run just stock before I get it tuned on vipec/wired in (so I can break in motor properly)
    Driver side fender
    Bumper
    Bumper cover
  3. #43
    Tacoma, wa
    Update: ordered
    p12 bellhousing
    p12 slave cyl
    axle bracket from mazworks
    ka24de stage 3 clutch
    gspec flywheel
    and some ~600cc injectors
  4. #44
    Tacoma, wa
    Cleaned, before primer
    Paint: 2 cans aztec red
    1 can clear coat with hardner
    Heres the damaged area
  5. #45
    Bothell, WA
    Slapped 5 Times in 4 Posts
    Everything seems to be coming along smoothly.
    ..... << Yuh dun know!!
  6. #46
    Kamil WifesCar is offline
    Dec 2011
    Buffalo NY
    Just please promise that you'll respect us QR users out there In my honest opinion, I love anything that performs, I just hate those that brag about it. But you don't seem like this kind so good luck with everything and keep us posted!
    '95 S14 - KA24DE-T in progress
    '00 GC8 Impreza - daily/winter
    '02 B15 Spec V - "wife's car" - breaking in the fresh QR
  7. #47
    Tacoma, wa
    No worries. I dont like to brag about stuff like that. I actually defended the qr on sr20 forum haha.
    Whatever engine you decide to play with will get you there fast depending on how much money you throw at it, and how you address weak points.
    WifesCar likes this.
  8. #48
    Tacoma, wa
    Got the short block back today. Waiting on headstuds mid next week (sr20det rwd are 10mm, gtir are 12mm) then Ill slap the head on and add accessories, etc.
    Painted zbrakes black yesterday.
    Going to swap bellhousings soon.
    And bought a qg18 crossmember yesterday.
  9. #49
    Tacoma, wa
    All the bellhousing bolts off, and misc sensors, springs and bolts taken out too.
    (notice the labeled flash cards with bolts and misc pieces taped to them too)
    Annnnd how It sits now, I need to swap the internals to the p12 bellhousing, figured Id read up on it a ton more before I do anything else though (or ask my uncle or someone to supervise)
    Gears seem to look fine though luckily.
  10. #50
    Tacoma, wa
    Got tomei 260* 12mm cams, the engine is at a shop now, I didnt want to deal with the cam install (solid lifters require shimming and I didnt feel confident doing it)
    decided to go with a different turbo too, so ill be getting a tomei m7960, if not the larger option. (I would like the response over power)
    NEW! Tomei ARMS M8270 & M7960 Turbo
    Gears are swapped into the p12 bellhousing now too.
    Got brembos for the car too.
    Got arp flywheel bolts, but the flywheel I bought was for a rear drive sr, so the bolt holes have to be bored out.
  11. #51
    Tacoma, wa
    Cams, fuel rail, rocker arm stoppers, injectors, and pulleys and mounts were installed
    also finished the assembly of the transmission.
    Bought a drill press, and drilled out my rear drive spec aluminum flywheel bolt holes to fit 13mm bolts, installed and torqued those arp flywheel bolts, followed by the act clutch, and finally the transmission was attached with 2 bolts to test fit a rear drive sr20det starter (dont think it will work, but maybe if I cut some water neck brackets the solenoid might clear)
    Also need the gasket for in between my engine and tranny...
  12. #52
    Feb 2012
    The motor looks amazing ...I wish I had the time and money to do this....what are you building it for road course or drag?
    Sent from my DROID RAZR using Tapatalk 2
  13. #53
    Tacoma, wa
    Mounted engine... Kind of.
    I need to figure out how to mount it on the passenger side and make brackets for the crossmember.
  14. #54
    Feb 2012
    Is that and AE86 in the back
  1. 05 spec-v engine is the same as a 08 altima engine?
    By wickedonez1986 in forum General Maintenance
    Last Post: 11-21-2010, 10:57 PM
  2. 04 spec v engine with 73k
    By beat it in forum Parts for Sale
    Last Post: 08-22-2010, 09:34 PM
  3. 03 spec v needs engine
    By 08blockspec in forum Vehicles for Sale
    Last Post: 04-29-2010, 08:31 AM
  4. WTB: Spec V Engine
    By 03sunburst in forum Parts Wanted
    Last Post: 04-27-2010, 04:05 PM
  5. Should I replace my v spec engine with a 2.5 altima engine?
    By 04vspec in forum Engine Swaps, Builds
    Last Post: 10-22-2009, 03:53 PM
