Results 1 to 20 of 35
Like Tree4Likes
Thread: Ramrods Track BUILD UP
    Default Ramrods Track BUILD UP
    After much weighing of options and trying to get my VQ swap off the ground. I have decided to take the big step and rebuild my QR to withstand a thorough beat down and come back for more. The end result (NA/BOOST) is still up in the air but a strong foundation will be laid for whatever is decided. I'm starting this thread to document everything and hopefully get some good feedback and help from you guys. The car has seen a bit of track time but I took last year easy as it was starting to burn a bit of oil and thought it wouldn't be smart to push it hard anymore. I'm hoping to return strong this year and humble some other drivers out there with big money cars.
    Wish me luck
    The parts have slowly started trickling in and hopefully I should have everything I need in the next month or so.
    PARTS INBOUND
    07+
    crank assembly
    signal wheel
    signal wheel bolts
    crank pulley bolt
    valve stem seals
    head gasket
    rear main seal
    head bolts
    rods
    Waiting for crank and rods to show up so I can match the proper bearings.
    Currently I'm undecided on which piston to go with. The 07 Spec is on the list of possibilities. 2J suggested a frontier piston for lower compression which would go nice with a treadstone kit. decisions decisions. Please discuss.
    I just got the block back from C&C Performance in Manassas VA. They honed the cylinders, cleaned the deck and washed the block. It came out looking great.
    The head got dropped off today to be ported. Along with a 3 angle valve job and de-shroud. Then it will be reassembled with JWT springs, new valve stem seals, C1 cams, and maybe some titanium retainers if I can find them. Planning on spinning to somewhere around 7200rpms after a reflash.
    2J Racing came through and shipped me the last set of slotted only rear rotors they had. These should replace the tiny stock sized rotors nicely.
    For now I wait for parts.
    Team ramrod. Lol
    Booyah!
    Ray Solis Pfbspecv is offline
    Oct 2011
    Tucson Arizona
    i got the same big rear brakes sitting in my room! lol but get the bc retainers. thats also sitting in my room. c1 cams, titanium bc retainers, and the jwt valve springs.
    My Spec V was once stock!
    Check out my build thread.
    you using new pads? if so have fun with that. not much room with new rotor and pads. took me a while to get them on
    Oct 2011
    Tucson Arizona
    Quote Originally Posted by shift_03specv View Post
    I havent decided yet. I might use the same ones i have on now. If anything my buddy will help me and we will rent that press tool from autozone.
    This fat ass box showed up today.
    What's inside?
    07+ crank
    Valve stem seals
    07+ rods
    Altima/frontier crank trigger wheel with bolts
    07+ head bolts
    07+ headgasket and rear main seal
    picked up these springs from 2J-Racing
    I'm picking up the head tomorrow. Ported with a 3 angle valve job and deshrouding. Need to order bearings and piston rings tonight and decide on which pistons to run.
    Anyone have opinions on pistons??
    Dec 2009
    How much was your crank if u don't mind me asking. I think the cheapest I found one was for like 479.00
    Low is a Life Style
    yep 479 at courtesyparts.com
    Jan 2007
    massapequa
    why not do 11.1 compression with travis new supercharger??
    Quote Originally Posted by silvabullit View Post
    still waiting on him to return my emails to get my vq swap started.
    Heads ready with new springs and seals installed
    exhaust side
    intake side
    Valves got a deshroud and three angle. Also the bowls were cleaned up.
    2J//All Day Joe@2J-Racing is offline
    Supporting Vendor
    Underground Atlanta
    Slapped 13 Times in 12 Posts
    Great thread! You know which pistons we suggest
    Pressit? no.. Hammer it.. yes
    [B] Please visit >> www.2j-racing.com
    2009 NASA National Champion
    Quote Originally Posted by Joe@2J-Racing View Post
    yeah but what year? I almost pulled the trigger on some spec pistons last night but they didnt have my grade listed.
    Got bored, still no word on when my parts will get in. Decided to clean up my shitty clear coat on all my CF pieces. This stuff came out looking good.going to do the hood, trunk and roof next
    These came in from NISSPORT today, water temperature and oil pressure gauge adapters with an extra port for an oil feed line to a turbo. No need to tap the oil pan
    Perrin universal steering column gauge pod mount will house some prosport halo gauges.
    still waiting on one fkn bearing. what BS!
    got bored sprayed the block in high temp 2k* primer and flat black
    ash likes this.
    Feb 2012
    Very nice....good luck with the build.
    sent by a ninja monkey phone
    Feb 2012
    Raleigh, NC
    Slapped 7 Times in 5 Posts
    Quote Originally Posted by thesammythecurse View Post
    Team ramrod. Lol
    All seriousness, good luck dude, looking good so far.
    A fresh JWT clutch and pressure plate came in last week to replace my old one. The old one still has some meat on it if anyone's interested, I just decided to freshen it up since everything's apart.
    Lower temp thermostats
    I ordered a few turbo goodies that should be inbound shortly.
    There's something NASTY coming soon.
    FK YA!
  1. Replies: 2
    Last Post: 12-15-2011, 12:44 AM
  2. Replies: 1
    Last Post: 07-25-2011, 05:03 AM
  3. ricey for track or not?
    By Splash45 in forum Forced Induction & Supporting Modifications
    Last Post: 08-25-2009, 03:35 PM
