im about to buy an 02 ser, what will i need to put my 04 specv engine and tranny in it? or will it just fit in?
It depends on the engine in it.
If it has the SR20 engine, then no, you will have to do some work to make the QR fit.
If it has a QR, then I think that it might drop it.
Others will chime in in a bit.
<< Yuh dun know!!
sweet guys thanks i thought it would just had to check thanks a lot.
If I were you, I'd swap the harness, ecu, cluster, pedal, and MAF over as well.
Or he could buy one of Alex's (MoltenNismo) jumper harnesses and skip the whole harness swap. 04+ ecu and MAF are worth the trouble IMO.
Ok i was thinking of swaping it all have whole running 04. Where can i read about this jumper harness?
I was actually gonna do a whole interior and engine bay swap
