quick update...
The diagram on the left is the only set of cams they have which will work just fine with stock springs
The diagram on the Right has not been made and still in production, And you will need aftermarket springs. When will they come out? IDK
today is the day. will see how much hp theses suckers can push.
EDIT: forget, there dyno isnt working.![]()
First post updated. I spoke to dustin from Brian Crower and they are continuing producing cams for the qr25. More studys have been done and they said for agressive n/a setups go with the stage 3. For F/I or nitrous apps, go with the Stage 2 cams
Just ran across this.. Thanks for this thread.
Without timing control, and completely N/A. If he was say, aiming at huge hp numbers, with a huge turbo, those big ass cams would let him make more power than he otherwise could. Race cars run big ass cams not because vthey would get gains N/A but because they need the additional detonation prevention to make their silly power.
Unless you are going to try for nutty power, run JWT or S2 cams.
get tapatalk
what if you got a fully built head but all motor but wanna run spray also what do u do there
so bc3's arent worth it over s1s?
im stuck between these 2 now
03 Silver Spec-v
Bolt-ons, and some N2O
