Results 1 to 20 of 31
    Supporting Vendor
    Oct 2008
    Default FI-R: Turbo VQ35 Spec V.. fire up video!
    Finally settled on a setup that I like (scrapped two previous designs), and got it all fabbed up..
    [ame="http://www.youtube.com/watch?v=K51GNC000TA"]YouTube- FI-R Turbo VQ35 Spec V..[/ame]
    Got it cranked up yesterday.. I still have to install the meth injection kit, fans, gauges, and misc. stuff, but, it should be driveable this week.
    This thing should spool up at around 2500rpm, and make ~400whp @ 7psi. This is our new CNC profiled compressor wheel, with a T350 turbine, in a .63 A/R T3 housing, and .60 A/R T04E compressor housing.
    The goal was to build a super-responsive setup, with minimal lag, and a HUGE powerband, with tons of area under the curve. The piping length sorta inhibits our goal, but, we'll see how well it turns out.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Default Re: FI-R: Turbo VQ35 Spec V.. fire up video!
    The way the piping sits in that vid is that permanent?
    Supporting Vendor
    Oct 2008
    Yes.. it is.. why?
    www.fi-r.net
    985-791-1826
    Nissan Performance
    i dunno if im seeing right but no i/c?? or you plan on using water-air?
    Yes.. it is.. why?
    Just wondering why you chose not to use an intercooler.
    Using only meth for cooling it seems...
    imagine the responsiveness from that turbo.... mmmmm....
    Supporting Vendor
    Oct 2008
    No intercooler..
    We're going to run methanol injection, which is a great means of "chemical intercooling"..
    By using a water/meth mix, instead of a traditional intercooler, there are huge advantages:
    Methanol (when it mixes with the gasoline, passing the injectors), increases the NET octane to about 96-98, at a 50/50 water to meth ratio. This makes the engine less prone to detonation, and allows more aggresive timing advance.
    Water vapor/mist pulls heat out of the intake ports, combustion chambers, valves, etc.. and helps to cool down the charge air temps.
    Less/shorter piping means A LOT less lag, and better transient response.
    There are people running 100% meth, and 20+psi, with no other means of intercooling. The only downside, is that you have to fill the tank up.. However, we will be using regular old windshield washer fluid (40% meth/60% water), and it's available for 1.50 a gallon. That should last a week or so.. depending on how heavy of a foot my customer has.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    ^^^That's great, I never knew it lasted that long, I thought a gallon would last a couple of hours at best.
    Question, if the tanks runs dry and the driver doesn't know or isn't paying attention, does the motor go "boom"?
    I mean I guess he will monitor his EGT's etc...
    Supporting Vendor
    Oct 2008
    Quote Originally Posted by B15NewYork View Post
    There's a warning light for when the meth gets close to empty. Even if it DOES go dry, at 7psi, he would have to really hammer on it to blow the motor.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    You've thought of everything haven't you.
    ahhhhh, ok cool... you dont usually see boosted street driven cars without some sort of intercooler. but sounds good to me lol
    Supporting Vendor
    Oct 2008
    Quote Originally Posted by Scrapin View Post
    While it is true that the main idea for intercooling has been the air to air cooler, it's honestly the least efficient out of the bunch.. especially on a street car that gets driven in traffic. Meth injection is 100%, every time.. no worries about heat soak, and variatons in effectiveness. With meth, you can tune around a constant percentage of effectiveness, and not have to worry about it.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Bob Lablah paperdukie is offline
    Suffolk/Queens
    Hmmmm interesting but you're right about the massive advantage of meth vs. Air to air intercooler. Nice build man that car is gonna rip.
    Supporting Vendor
    Oct 2008
    Pulled my hair out for most of the day, trying to diagnose a misfire problem at idle, and on tip-in. Turns out, the MAF didn't like being so close to the turbo and/or the pipe going from 2" (turbo outlet), to 3", in about 12", created a weird flow pattern across the element. So, I had to rework the charge pipe, and set the MAF back before the turbo (draw through). After some cutting/fitting, everything worked out great, and the problem is solved. I buttoned up the return fuel system today, as well, and it's now running on that setup. Tomorrow, we will probably get to drive the car late in the evening. I'll shoot some video footage if we get to that point.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    How much cooler does meth make the IAT? Highway crusing in about 40* weather i see about 60* IAT w/ my intercooler.
    g35
    Kurtis g35 is offline
    New Hampshire
    Man that looks nice. Where is your shop located at?
    Louisiana iirc.
    NA Jay OrangeUaVol is offline
    SW Tennessee
    Louisiana iirc.
    You are correct sir.
    You sure know you're shit Travis... if I ever do anything crazy with my whip I be headin' for Cajun country. I'm glad to see someone make a name for the Nissan/Spec community. You are a master of your craft.
    **FOR SALE** Optima red-top battery
    Supporting Vendor
    Oct 2008
    Well, cruising, the temp should be about the same as ambient, with a slight warmup, depending on where you draw your air from (into the turbo), and how much piping is exposed to underhood heat. We're pulling air out of the driver's side bumper, and have a very short route to the TB, so, I'd say that IAT's will be close to ambient.
    In boost, the cooling factor will be constant, although, immeasurable, because most of what's going on, in terms of cooling, will occur in the plenum/runners and the combustion chambers (with the only variation being heat soak from the 20" of piping, from the turbo to the TB, and the intake manifold itself).
    www.fi-r.net
    985-791-1826
    Nissan Performance
  1. Racing Fire retardant Jacket
    By executiV in forum Parts for Sale
    Last Post: 07-14-2009, 02:49 PM
  2. My New Turbo Video
    By wolfe715 in forum Video Games & Multimedia
    Last Post: 05-12-2009, 02:17 AM
  3. CL: Turbo VQ35 4th Gen.
    By Scrapin in forum Parts for Sale
    Last Post: 04-20-2009, 05:25 AM
  4. UpRev and turbo stuff video
    By ash in forum B15 Sentra (2000 - 2006)
    Last Post: 01-21-2009, 03:32 PM
  5. my brother's car on fire (pictures)
    By Spacecowboy959 in forum B15 Sentra (2000 - 2006)
    Last Post: 04-09-2006, 02:58 PM
