Page 1 of 15 1234511 ... LastLast
Results 1 to 20 of 295
Like Tree5Likes
Thread: FI-R - Yogi B gets a Big Bore/Stroker VQ, Standalone EMS, and other goodies..
    Supporting Vendor
    Oct 2008
    Default FI-R - Yogi B gets a Big Bore/Stroker VQ, Standalone EMS, and other goodies..
    Ok.. We're starting over here.. This post is not intended to hurt anyone's feelings, start drama, incite riots, name calling, childishness, etc. If you cannot abide by that, you will be removed from this section.
    Barry's car is currently at another shop, getting suspension and brake parts installed, in preperation for a fresh powertrain install.
    As you have seen from the other vendor's post, his car was picked up on a tow dolly. After 200+ track passes, and daily drive duty, the engine is in need of a rebuild. It ran strong and posted some low-mid 12 second ET's, spinning close to 8k rpm on pump gas. It is a proven FI-R built car, with lots of thought into the head design, internals, etc.. The car is not in "sad shape". It has been down for a while as Barry and I have been working together financially, and technically to make this whole project come to life. It cannot be built in a few days. This kind of thing takes months and months of preperation.
    This time around, it will recieve a 4.1 liter big bore/stroker motor, with our freshly developed CNC heads. We are working with a head shop to have our own hand ported heads scanned, and a head porting program written for us. We will offer this later to you guys as a set of bolt-on, fully loaded CNC ported heads.
    The heads have been tested on a larger bore fixture, at the size we'll be using, and we have some very nice numbers.
    In addition Barry's car will recieve the following:
    - Long tube headers
    - Custom sheet metal intake manifold
    - JWT C9 cams/springs
    - VQ30DE(k) cooling mod
    - 2.25 to 3" equal length y-pipe
    - Full 3" exhaust
    - Pro EFI standalone engine management
    - FI-R Pro fuel system
    - Direct port nitrous system (200hp capable)
    - FI-R Drag-Bag suspension supplement kit (prototype)
    - FI-R Removeable traction bars (prototype)
    - Custom 3.5" "ram-air" inlet system
    - 3.5" LSx throttle body
    - Conversion to MAP sensor
    I'm sure there's a few things that I'm missing.
    I will post up pics when we go and get the car with our car hauler. That will happen in a few weeks.
    As far as power estimates, I'm hoping for around 330-340whp all motor.. but it could possibly make more. We will use progressive controlling on the nitrous system, through the standalone. It will have it's own seperate fuel system/tank, so we can use race gas while spraying.
    I will check the car over when it gets here, and hopefully everything will be compatible with what I'm planning on doing.. as I'm not quite sure what is being done to the car right now.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Arizona
    Is Barry set on staying away from boost? Because his car would be wicked with a turbo...
    Lol, I thought I had seen this thread as a "new topic" before...
    Look forward to seeing this thing run
    Supporting Vendor
    Oct 2008
    Quote Originally Posted by SlowCarGuy View Post
    I don't know if he's set on it.. but, I wouldn't recommend it. For what Barry intends to do with it, I don't think turbocharging is practical. I wouldn't recommend it. He likes to go out on the weekends and play at the drag strip, and I'm sure he's going to get more into road racing, as well. So, we have to build something that's going to survive at that level. The logistics and available space make it almost impossible.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Old Hickory, TN
    I revoke my previous statement. Not going to be polite to a true asshole
    Wish I was cool and could edit other members posts without their permission and without being a forum moderator.....way to go king douche
    Supporting Vendor
    Oct 2008
    Quote Originally Posted by Staceys02specV View Post
    Good luck!
    Look forward to seeing great things with this car
    tapatalk FTW
    Thank you.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Supporting Vendor
    Oct 2008
    As far as the stroke increase.. We're offset grinding a stock crank, and using a smaller diameter rod journal. Here's a little chart explaining the process:
    Nothing new.. this has been done for years with other engines. The good thing is that the VQ has a relatively large rod journal to begin with, so we can ge a decent bump in stroke, and still retain a 2" rod journal.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    If this build can handle 200+ HP of nitrous, why not go boost? In principle nitrous does the same thing as boost correct?
    I think a motor this violent should be boosted. 500 WHP would be brutal.
    05 Red Spec V. Fully Bolted -Cams.
    Quote Originally Posted by mot19 View Post
    Cupids already done it
    Arizona
    SuperSpec (one of Travis's builds) Is expecting to hit 900hp this year... But thats on an SQR.
    Its all up to Barry, anything is possible with enough money.
    Supporting Vendor
    Oct 2008
    It would be fun.. but, keep in mind that Barry doesn't intended to drive this thing around at that level every day. It's a daily driver for him.
    If you look at trying to keep the car cool in the area that he lives, while road racing, and a heavy drag schedule when he gets out to the track.. turbocharging just doesn't really work for him. From previous experince on other turbo VQ vehicles.. heat plays a big factor. For folks who aren't really competing hard, and just play on the highway/drag strip every now and then, a turbo VQ is cool. But, in a competitive setting, I don't know if I could make it reliable enough.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Supporting Vendor
    Oct 2008
    Quote Originally Posted by thesammythecurse View Post
    No offense.. because I know he's laid up at home right now.. but, I haven't really seen his car do much of anything that a high 300whp Spec V can't do. He ran high 11's @ 115mph. Jerry's car did that at around 375whp. Not saying his car isn't capable of making 500whp on a dyno.. but, from what I've seen, he has a long ways to go.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Snapple Fact.
    Old Hickory, TN
    Al is still sick??
    tapatalk FTW
    Supporting Vendor
    Oct 2008
    I guess.. I haven't seen him posting on here in quite some time.
    www.fi-r.net
    985-791-1826
    Nissan Performance
    Bob smokeyV is offline
    New York
    Consider that his goal may not be to make the most amount of horsepower possible. From what I know of Barry, he wants to run track times, have a daily driver and get into AutoX.
    Just because you make 500whp on a dyno doesn't its all fun and games at the track. If you want that to stick, it takes some good suspension adjustment and a knowledgeable driver. Nitrous will help him get the drag times he wants. Having a strong N/A motor will be glorious for a daily and in AutoX.
    Personally I think this car is awesome. It seems to have more legitimate planning than any other B15 out there. The fact that his build is starting to come together and he will finally be putting the ProEFI to use makes me tingly.
    Cant wait for more pics
    Jerry jwl013 is offline
    AL
    cant wait for updates on his and mine...hint, hint
    The Nissan Family...
    02 Spec VQ (11.97@115 http://www.youtube.com/watch?v=xRkKUBbFzs8)
    05 Altima SE-R (dd)
    95 240 (610whp SR powa'd http://youtu.be/ToH7FyHvS2E)
    05 Armada LE (the wife's)
    BC, Canada
    You said in the last thread that this motor was revving out to 8K. Will he still be able to rev to 8K? Will it continue to make power up there (did it before?)
    Quote Originally Posted by njord View Post
    na now that travis had to make a new thread it will only be able to rev to 7.5k...
    Puerto Rico
    can't wait to get my vq swap
  1. All B15 Models 2JRacing - Yogi B gets a Panhard, Big Brakes, Bent Beam, UR Braces
    By Joe@2J-Racing in forum 2J Racing
    Last Post: 05-06-2012, 10:19 PM
  2. All B15 Models 2JRacing Big Bore Throttle Body Kit
    Last Post: 12-11-2011, 08:48 PM
  3. VQ 4.2 liter (big bore/stroker) update..
    By Trav4011 in forum Engine Swaps, Builds
    Last Post: 08-17-2010, 12:20 AM
  4. FI-R: Barry's big bore, high comp VQ39 build..
    Last Post: 03-11-2010, 02:19 AM
