Results 1 to 5 of 5
    Default Boost Controller Problems
    Hi my name is Danilo from Costa Rica.
    First post here.
    i was running back to play some drums and woops something didnt felt right, ok i think my boost controller is not working properly(Greaddy Profec B Spec 2), i ck the solenoid it sounds when i put air in to the head unit,so solenoid working fine, change vacuum lines all good, change hoses from piping , same issue, after a couple of shots i tight the waste gate a little bit more boost is build up but still no response from the controller. CK WG it works fine it does not stuck, i dont know what could be the problem here any idea how to test the controller by it self.
    PS: There is a difference between the readings of the boost gauge and the boost controller, is this normal?
    Thanks...
    Ashwin ash is online now
    Default Re: Boost Controller Problems
    how much of a difference? It should be the same
    Its about 1psi sometimes 1.25 more in the boost controller than in the gauge.
    Another question how do you connect your solenoid? Regarding Com port to WG and NO to Turbo Housing?
    I have it like this:
    NC T'd to Bottom of Wastegate and Compressor Housing
    COM to Top of Wastegate
    I have a single actuator. So my set up Com port to WG and NO to Turbo Housing
    Just to see if it is ok.
    Still have no clue with what happen with my bc, i have test it and it works
  1. Boost Problems - Car Stumbles Under Boost
    By Ponda in forum Forced Induction & Supporting Modifications
    Last Post: 06-07-2010, 09:30 PM
  2. Greddy Profec B 2 - Boost controller manual
    By ash in forum General Guides, Documents & Downloads
    Last Post: 08-12-2009, 11:37 AM
  3. wtb: electronic boost controller
    By str8rpn in forum Parts for Sale
    Last Post: 07-19-2009, 07:30 PM
  4. Wtb boost controller
    By nismo2ner in forum Parts for Sale
    Last Post: 06-11-2009, 04:03 PM
  5. Replies: 9
    Last Post: 05-20-2009, 12:06 AM
