any updates on this?!?!?
can u give a list of everything u do have?!?!? we all want to make power if someone has done it right they should share.. nothing better than seeing B15s making good power n having everyone in the tuner scene hate.. cuz no one believes in the QR like we do..
which wolf standalone are you going with ?
2004 BMW 325XI AWD Turbo Auto - standalone engine and trans controller - SLC_OEM - 62mm turbo
1994 Toyota Supra Twin Turbo - AEM V2 - in the mail bugatti veyron pump, 1000cc ID, T72
2004 Nissan SE-R SpecV Turbo - standalone, j&s safeguard, modified stock injectors. (gone)
Both cam and crank will work with the v500,BUT you have to modify the tone rings so the motor have to be pulled apart.
gotcha. have you seen what the crank angle and cam angle wheels look like ? if you're going to pull the motor apart to modify the crank angle, the 02-06 crank wheels could actually have a gap machined into where there's a missing gap to make a proper missing tooth wheel, the cam is going to be tougher. you'll have to fill the metal on the plate, maybe weld it, and then machine a single gap, or machine a 50/50 style on the end of the cam.
alternative is to run an external 36-1 on the crank pulley and run batch/waste spark.
I really was going to go that route,but had the motor apart for my built.So i did
some old mods to the wheel.did a set up like this to my 9 sec twin turbo mustang in the 90's,built a whole new wheel on the front of the crank.
Here is a launch from turbo spec v
[ame="http://www.youtube.com/watch?v=SxK_BPYtrtU"]http://www.youtube.com/watch?v=SxK_BPYtrtU[/ame]
car sounds beast. any mod list on what you have done to it? and did anyone notice the sirens going off in the first video lol
for a launch that = FAIL LOL but that's a nice burnout tho!!
I think that you should change that from launch to burn out...lol...
Props though.
<< Yuh dun know!!
