Results 1 to 5 of 5
    aaron specvt06 is offline
    Lafayette Tn
    Default 2 simple questions about going turbo
    Just a couple simple questions. Turboing my 06 spec v and I need to know where is the best place to run my oil feed line to from the Turbo? And can I put the maf between the bov and throttle plate and vent to atmosphere or does it need to be after the bov or does it need to be on the intake pipe on the Turbo?
    Jan 2009
    Hagerstown
    I have always used a oil filter sandwich for feed line
    This is how it goes: Throttle body-Maf-blow off
    Lafayette Tn
    Ok thanks I forgot bout those sandwich adapters lol and I'm guessing just do the return line back to the oil pan correct?
    Nov 2007
    for the return line, i used the same point as the turbonetics kit... so if you can find that manual, its a good reference. Also, for my feed I used a nisport adapter, which fed off the oil pressure sensor. It was pretty easy using a 27mm socket to get the stock sensor off... this way allows for you to safely monitor the oil pressure incase it suddenly drops.
    Arizona
    The return line should go into the upper oil pan...
    For oil feed, I like the Nissport adapter much better (i've had both)
    NISsport Oil Pressure Adapter for B15 SE-R, Spec V, Altima
  1. my 02 turbo questions
    By inspected in forum Forced Induction & Supporting Modifications
    Last Post: 02-07-2011, 03:13 PM
  2. Is it this simple? (Max Content)
    By Montreal1.8 in forum Engine Swaps, Builds
    Last Post: 01-05-2011, 02:57 AM
  3. QR25DE Turbo Questions
    By kr3wskaterr93 in forum Forced Induction & Supporting Modifications
    Last Post: 11-18-2010, 02:17 PM
  4. New guy 04 spec v simple question ....
    By Genox777 in forum Introductions
    Last Post: 07-28-2010, 09:47 AM
  5. jsk8r57's turbo build and questions
    By jsk8r57 in forum Forced Induction & Supporting Modifications
    Last Post: 05-24-2010, 03:38 PM
