I placed this n the turbo section since the info is for my Holset build...looking at trying to find out what the oil pressure is on idle and 6K rpm on our motors...to figure if I need to get -3AN or-4AN w/ restrictor for the oil in...if anyone has this this would be GREAT!
All are approximates from the FSM:
14psi@Idle
43psi@2k
57psi@6k
WOW, those are some low numbers. i idle at 45-50 when hot and WOT hits around 110psi...this is on the sqr though.
These are way off for me... mine are closer to:
20-30psi @ idle
70-80psi @ 3k
100ish @6K
Wow that should be great for the Holset than...it need no less than 10 @ idle and no more than 70 @ 6k....I see too many other 4 bangers with this turbo running restrictors mainly since they have over 100 psi of oil pressure...BUT to be on the sfae side I plan to place a temp oil pressure gauge and see the exact pressure that would be feeding into the turbo...thanks for the help guys!
Just make sure you wait for the oil to heat up cause it will definitely go over 70 when cold. Mine used to go over 120 when cold and reved to 4k. And you will need to run 0w-20w. To get that low of numbers. And I had over 160k miles on my 04.
Up to ten current and previously owned Nissan Products....
Current is My 05 Aztec red Spec and My wifes new '12 pearl white sentra SR SE.
So getting thinner oil is better to keep low oil pressure then. Can you find 0w-20w at any standard place? like Autozone?
Yes, thinner oil = lower oil pressure. Too high of pressure means oil isn't going where it needs to which is generally not a good thing.
And you should be able to pick up 0w20 at Autozone I believe. Otherwise Redline makes a great 0w20 if you don't mind spending a few extra bucks.
0 is the cold viscosity, 20 is the hot viscosity. I know hot is tested at 210* F, not sure on the cold.
But basically a 0w30, 5w30, and 10w30 are all the same thickness when warm, the only difference is the thickness when cold.
gotcha so the 20 is thinner oil when it's hot. Thanks
I'm hitting 15 at idle but around 2k it shoots up to 60-70. I havn't even hit 6k yet! my oil pressure is gonna max lol. I'm using 10w30 mobile 1.
Oil to new and thick?
frozenbarb my oil pressure reads the same (im not boosted tho) i think it has to do with the sensor placement is yours in a sandwich plate?
Sent from my MB300 using Tapatalk
03 Silver Spec-v
Bolt-ons, and some N2O
Yeah it;s in a sandwich plate but the new oil is very thick so I'll let it break in first.
I'm using 5W-30 like normal...after warming up I get it to about 60psi on WOT...on idle its at 10+...so its working fine with me
