Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Like Tree18Likes
Thread: Turbo kit is in, Could someone check if my oil lines are good?
    Sep 2009
    Queens,NY
    Slapped 5 Times in 3 Posts
    Default Turbo kit is in, Could someone check if my oil lines are good?
    I want to double check everything before I start the car up.
    Couple questions.
    Is there a way to prime the car so every oil/coolant/fuel gets to where it needs too?
    Are my oil return and drain good?
    I'm afraid of my oil adapter leaking or fuel leaking.
    Thank you, take a look at the pictures.
    Any tips after startup?
    Oil feed coming from a sandwich adapter
    Oil return- It takes a spiral because of where I tapped it.
    DIY DUMP TUBE
    8$ exhaust flexible tube from vatozone
    8$ ebay wastegate flange
    some welding that blew holes in the tube with some JB weld.
    You have to do some bending and slight hammer to get it to bend
    16$ home depot catch can with barb fitting
    Engine bay.
    Ashwin ash is online now
    What is that in your dump tube?
    The return line will be fine as long as it will allow oil to drain back into the pan freely via gravity.
    You can test your feed line by disconnecting it from the turbo and just give the engine a quick crank once or twice (DONT START IT) to see if oil squirts out.
    only way to know if there are leaks is to start it up.
    Sep 2009
    Queens,NY
    A tail pipe turbo whistle
    Quote Originally Posted by frozenbarb View Post
    Apr 2009
    Way to nigger rig shit.
    Excuse my language, but jesus christ.
    Sent from my DROID BIONIC using Tapatalk
    castrob15 likes this.
    Preston
    My Photo Album
    My flickr
    StanceWi.com
    TheSpecvBoard.com
    TDMImports
    Ravage Performance
    2004 Nissan Sentra SE-R SpecV
    Quote Originally Posted by Specv118
    this needed more kanye west reference.
    example: Darson your build is cool and all and ima let you finish but Travis has built the best car of all time! all time!
    Sep 2009
    Queens,NY
    Quote Originally Posted by specv118 View Post
    LOL I have time but no money, the whistle can go on & off that is if it doesnt get melted by the rich flames.
    roy risforroy is online now
    shitsville, ky
    pull your fuel pump fuse and pull your feed line off the turbo. take a mcdonalds straw and dip it down into a quart of your oil, put your finger over the top of the straw (holding the oil up in the straw). put the end with oil in it over your oil feed inlet, and let the oil run down in the journal until its full (won 't take much and you can hand spin the impeller to spread the oil across the journal. put your feed line in a jar or bucket, crank car 2-3 times in 3-5 second burts and you should have oil out of your feed.
    put it all back together and profit.
    only way to check for leaks is to pressurize the system and drive it.
    Apr 2009
    Lololololol
    Preston
    My Photo Album
    My flickr
    StanceWi.com
    TheSpecvBoard.com
    TDMImports
    Ravage Performance
    Hope that dump tube doesn't melt of blow off...if it does you're gonna be melting shit left and right lol
    Sep 2009
    Queens,NY
    OK, I started up the car and everything seems normal.
    NO leak at the injectors or the oil sandwich adapter or at any oil line.
    The AFR is acting funny. It goes from 10.2-11.3 and slowly creeps up to 14.0 then back down then back up again.
    car feels normal just a little louder
    255pump is also loud as fuck.
    Gary un33dit is offline
    LI NY
    I had a similar problem when I did my injectors. I ended up buying new injector seals/orings and that fixed my problem...there are many things that could cause that though.
    Slapped 16 Times in 15 Posts
    That's cuz you're making baby power my motor takes care of the wally hiss issue.
    Kyle kktohot is online now
    DFW
    yeah I can hear the walbro pump over my engine/exhaust outside the car
    Sep 2009
    Queens,NY
    BUMP new problem,
    I replaced my injectors Orings and removed a old oring stuck in cylinder 4s injector hole. Even after that my AFR increase from 10-14 and then decreases in a cycle. Any reason why"?
    Doug E. Fresh SilverBullet is offline
    M'boro TN
    Slapped 3 Times in 2 Posts
    whats with look on the oil feed line?
    Travis raysh is offline
    buffalo, mn
    nuts
    Quote Originally Posted by raysh View Post
    nuts
    You called?
    xbrandonx and L8YBUG like this.
    buffalo, mn
    lmao, naw man. i saw he fixed his problem in another thread.
    sorry for throwing up the *NUTS* signal
    Sep 2009
    Queens,NY
    Quote Originally Posted by SilverBullet View Post
    too much line engine not big enough.
    lmao, it's the batman rescue signal!
  1. turbo oil lines
    By dart2424 in forum Parts for Sale
    Last Post: 10-01-2011, 05:02 PM
  2. WTB Turbo oil lines and more
    By Nperez1986 in forum Parts Wanted
    Last Post: 09-19-2011, 06:20 PM
  3. FS: Turbo oil feed/return lines, Stainless
    By beow in forum Parts for Sale
    Last Post: 10-12-2010, 09:04 PM
  4. Turbo oil parts lines,fittings etc.
    By nismospec671 in forum Forced Induction & Supporting Modifications
    Last Post: 04-18-2010, 10:46 AM
