Results 1 to 20 of 36
    Sep 2009
    Queens,NY
    Slapped 5 Times in 3 Posts
    Default AFR goes up and down 10-14 after turbo install. Need help tune going to sht
    I just finished my turbo install and my AFR is going out of wack. It starts at 10 and climbs to 14 and lingers for 3-4 seconds then slowly drops back down to 10 and back up.
    At first I thought it was because I lost a O-ring at the 4th cylinder injector hole but I found it and removed it and replaced my orings and it's still acting funny.
    What esle could it be?
    I'm using purple 577? srt4 injectors with a 255walbro. SAFC and my zt-2 is giving me weird numbers.
    from 10 t0 14 it takes around 20second and from 14 to 10 it takes 1 second.
    *Last page* NEW PROBLEM
    Have you tried pulling fuel under low throttle settings? Could be the ecu freaking out over the bigger injectors and being unable to keep afr's at stoich.
    2J//All Day Joe@2J-Racing is offline
    Supporting Vendor
    Underground Atlanta
    Slapped 13 Times in 12 Posts
    Where is your wideband.
    Is it a Zeitronix wideband
    Is your turbo new (leaking turbo will foul up your wideband reading with oil)
    Explain those readings vs RPM and Throttle
    Pressit? no.. Hammer it.. yes
    [B] Please visit >> www.2j-racing.com
    2009 NASA National Champion
    Sep 2009
    Queens,NY
    That does make a little sense, i'll try to pull some tomorrow.
    Quote Originally Posted by Joe@2J-Racing View Post
    My wideband is at the end of the turbo downpipe near the flange.
    Zt-2 wideband
    Turbo is used but how will i know if it is leaking oil? Bust open one of my intercooler pipe and check for oi l?
    It's still on ramps atm because I dont know if it's exactly safe to drive.
    Supporting Vendor
    Underground Atlanta
    Wait.. what?! HAHA.. its under no load.
    Sep 2009
    Queens,NY
    Even if it isnt under any load, shouldn't the numbers be still on idle?
    Also my oil pressure gauge isnt reading so I don't want to drive it just yet.
    Quote Originally Posted by frozenbarb View Post
    Yes, they should hover right around 14.7... I think Joe's drunk again
    danny, drive the car.
    Purple 577cc srt4 injectors...? The 577's are black and blue. Not sure what injectors you're using.
    Sep 2009
    Queens,NY
    Oh, finally did the research since the seller never told me the CC. They are stage0 527CC injectors.
    Anywho I'm going to drive the car tomorrow and find out how to pull fuel from the low throttle.
    roy risforroy is online now
    shitsville, ky
    you're tuning via safc? if i'm not mistaken, i'm pretty sure the ecu can only handle a +25% increase in injector size before it flips the fuck out and runs like junk at low rpms and idle. if that is 100% true, then your injectors may be too large for the ecu to handle at idle via an safc. but that's just my guess.
    also you won't be able to tune below 3k rpms (without unplugging your primary o2, which may or may not make your car run like shit). doing this pretty much puts the car in open loop all the time, so you'd be able to use the safc to tune idle, but even then it would still idle like shit. you need something much more efficient to tune with such as osiris or jwt reflash.
    but like i said, that's just my guess, i could be way wrong.
    The split second ftc1 still up for grabs lol Just saying
    Supporting Vendor
    Underground Atlanta
    Your AFRs are doing what they are supposed to, under no load. Dips, corrects, dips, corrects.
    You need to simulate load, either a dyno or road tune. With no tune, those injectors and FP, you will run pig rich.. It wont detonate. You'll be scaling back as much as 30%. Also, if your MAF is non-oem, it will cause some pretty poor readings.
    Sep 2009
    Queens,NY
    ^ yeaah I know but I don't want to hack up ecu even more and pay 500 for a tune at VTR..
    Sep 2009
    Queens,NY
    I see, so I'm guessing it might be normal. I'll go take the car out for a drive maybe the ecu will fix itself.. I'll be getting a street une on thuursday for high throttle.
    But if my ecu is freaking out on low throttle and I can't tune low throttle how do I correct the ecu?
    Get smaller injectors?
    Pretty sure my maf is oem too.
    You can tune low throttle, in fact you have to for larger injectors. Give it a try and see if it helps. AFR's should not be fluctuating that much IMO, but I've never dealt first hand with injectors that large.
    Supporting Vendor
    Underground Atlanta
    On tip in, under no load, it doesnt matter so much. His ECU isnt scaled for the injectors so its doing what its supposed to
    Jon 2k4spec is offline
    Washington D.C.
    :smh: BRING THE LUBE (NYers will know what i mean(some))
    but your in NY you got a lot of sentras around there... let them help yea, im sure you can also find some cheaper spots for a 2-3 hr dyno/safc tune.
    B15 - 04 - Panda - QR25 - S/C to Turbo
    The white rims are Rotas... 17x9 +25, yes they fit brembos and yes my fenders are rolled with 235s, DONT PM ME (read threads)
    and no they are NOT for sale and No i do not know where to find them.
    # of PMS about my rims in one day record 6 as of 2/12/2012
    If you want the rims you can buy the whole car
    B15 - 03 - Beater - QR25 - Stock
    B15 - 02 - Red - QR25 - Parting out.. PM me for parts!
    B13 - 92 - FlatBlack - SR20 - Restored, DD'ed, Sold
    Sep 2009
    Queens,NY
    The POS is still raising and dipping but i'm not sure if it does it when i'm driving at 2k rpm i'll test again in a few.
    I did all the relearns and it fixed something but I think i hear my throttle plate rattling. I'll upload the vid in a couple hour.
    I still have not tried messing with the low throttle fuel yet. I have to meet up with un33dit for a street tune.
    Do you guys think it's safe to drive for an hour or should I get it fixed first?
    On a side note, i was so excited my oil gauge was working i reversed off the ramps and forgot about the bucket of oil under my car.. and BOOM oil everywhere
    Sep 2009
    Queens,NY
    Bump, it's still dipping and sht even when driving and underload.. do you guys think it's safe to turtle a hour awaY?
  1. How To: Use/Install a Holset Turbo on your QR25
    By Nperez1986 in forum Sentra Specific Installation Guides & Technical Info
    Last Post: 01-30-2012, 10:16 PM
  2. Replies: 9
    Last Post: 09-25-2011, 10:19 PM
  3. tuning after turbo install
    By specvt06 in forum Forced Induction & Supporting Modifications
    Last Post: 05-06-2011, 11:17 AM
  4. Steve's Turbo Install
    By Ponda in forum Forced Induction & Supporting Modifications
    Last Post: 01-12-2010, 09:34 AM
  5. turbo install info
    By V-spectech02 in forum Forced Induction & Supporting Modifications
    Last Post: 04-12-2008, 04:59 PM
