Hi everyone, im wondering of how much power does QR manual transmission can take?
Also, i came from Altima and R32 world thats why not too shure about some things like: QR25 came only on SpecV's and with only 6spds???
What other options of transmissions do QR people have, i searched around and it looks like people can mate Maximas tranny internals with QR bellhosings??? I am i missread something?
What about any other engines like VQ30/VQ35, P11 SR20, 1.8 liters!
And will the Sentra and Altima transmissions interchange without modifications?
no swaps easily attainable. IF you'd like to try to swap a b16 qr tranny into a b15 Im selling one, but it ll take some work.
qr also came in the 2.5 altimas qr bell housing on a max tranny i here works..... i seen vq30 and 35 swapped in a spec v......
Reggie reg SO
SER ious
turned up to the max
The stock 6 speed tranny is a beast. So much so, that it's a pretty sought after tranny with some other nissan swaps.
It's hit 500whp, and the only mods are maybe cryo treating?
Some people put the maxima final drive for longer gearing, but that's all I've seen for tranny mods really.
i know Al has hit 500whp, and the blue car that i drive is well over 400whp and that has a stock maxima box which is pretty similar. andy and stevens cars are track beasts... sooooo.... dont worry about it, they arent blowing up like the sr20 boxes.
Thanks alot guys!
SO, all Sentras with QR were 6speed?????
Does anybody know if Altima 5Speed is same as Sentra 6sp, like identical housings, mounting point, Shifter linkages, Hydraulic clutch? Speedo???
I know this is very technical qestion but im planning to turbo QR Altima thats why im asking! (Not a dreamer))), look in signature for my previous Altimas))
no, SE-R's were 5 speeds. spec-v's were six.
i don't know about you guys, but i don't pussy shift my car at all. i have flatfoot shifted my car since i drove it off the dealership lot with 11 miles on it, and the trans is as smooth as god damn butter. and i'm still on the stock clutch with no slipping at 76k miles, 20 of which were boosted and beat on daily with plenty of roll and dig races, so that says a lot for the stock clutch, too.
trans is hella solid. but solid is only as good as the driver isif you can't get it in gear, you'll bust a tremec just as easily as you'll bust the old sr20 5 speeds.
All SER SPEC V's had a 6 speed with HLSD* no questions there. Some 04 and all 05-06 trannies have better gearing I believe, so if you go with a swap, try to find one of those preferably.
That's just what I've heard coming from people who swap from an 03 to an 05 tranny. and all B15s* had the HLSD, B16s had to pay extra. Lol
Ok, thanks alot once again guys,
To summarise for myself:
All B15 SpecV's, with manuals, had 6sp with LSD
All B15 SER's with manuals, had 5sp, with dif gear ratios over years
Im not going to swap anything yet, untill my Altimas tranny let go!))) In that case i would like to know which tranny i should hunt for!)
Last qestion!!!)))
Are the SPECV 6sp physically completely identical to an SER 5sp?
Same housing, same shifter linkage points, same mounts? Same Speedo?
Also, does anyone have a link to a website where i can see all the gear ratio differences through the years from Sentra and if Altima??? I tried the stickie but the link fails to open!(
EDIT: Found some info about 5sp vs 6sp interchangability!)
6 speed swap??
My Cardomain - Click
all spec v are 6 speed only and lsd im sure the ser bell housin with 5 speed is the same its on a qr engine
Reggie reg SO
SER ious
Motor: QR25DE (2002 SE-R)
Transaxle Model: RS5F51A
Model Code Number: 8U006
Number of Gears: 5
Oil Capacity: 2.3 Liters
Recommended Gear Oil: API GL-4, Viscosity SAE 75W-85
Gear Ratios
1st Gear: 3.153
2nd Gear: 1.842
3rd Gear: 1.258
4th Gear: 0.947
5th Gear: 0.772
Reverse: 3.002
Final Drive: 4.133
Motor: QR25DE (2002 Spec V)
Transaxle Model: RS6F51H (Helical LSD)
Model Code Number: 8U078
Number of Gears: 6
Gear Ratios
1st Gear: 3.416
2nd Gear: 1.944
3rd Gear: 1.258
4th Gear: 0.947
5th Gear: 0.772
6th Gear: 0.630
Reverse: 3.252
Final Drive: 4.428
ONLY THE 02 SPEC V HAS DIFFERENT GEARING (1st Gear Is the only difference, its super short)
03-06 are identical
I bought my 02 New, had Trans replaced with a 03 Trans @ 10K miles (manufacturing defect) it sounded like a golf cart it made a gear howling noise.
Want A Ported Intake Manifold?? $190 Bucks --shipped in the US-- PM ME
CORNDOG DRIVES A 440HP 450TQ QR25DET Spec V (proven)
All B15 SpecV's, with manuals, had 6sp with LSD correct.
All B15 SER's with manuals, had 5sp, with dif gear ratios over years. B15 SER 5spd has same ratios.
The 02 tranny sucks ass. 1 is way to short for me.
I beat the shit out of my car on a daily basis and I have not had a prob out of the tranny!
