Results 1 to 14 of 14
Thread: Colder Plugs.
    Cornelio CORN DOG is offline
    Mesa, AZ
    Default Colder Plugs.
    Ive been running the 1 step "colder" NGK Iridium LFR6AIX-11 For a lil over 1 yr (about 10K miles) No problems or issues. Im on the turbonetics Reflash.
    So far on 91 octane i can run 14-15psi with no detonation, BUT if i turn it up to 16-16.5 psi i get very very slight detonation on 91 (thats all we have) so im forced to go buy a few gallons of 110 octane if i wanna run upwards of 15psi
    My question is: If i go another step lower (for a total of 2 steps lower to the 7 range) on my plugs, would i be able to run more Boost with out detonation??
    Before you say use better gas (like 93) best we got is 91, Not going to E85 either so save that one too lol and 100 & 110 both run $7.99 per gal so NO
    Worse that can happen is a buy the 7's and they foul up and i have to go back to 6's (and ill be out a lil $$)
    Thanks in advance guys!
    Cornelio.
    Want A Ported Intake Manifold?? $190 Bucks --shipped in the US-- PM ME
    CORNDOG DRIVES A 440HP 450TQ QR25DET Spec V (proven)
    Joe joegem5 is offline
    Peoria, AZ
    It also may be too much boost on 91 octane. Every engine will have a limit on when detonation occurs. Increased boost causes more heat, higher compressive forces in the combustion chamber which eventually leads to some knock. Colder plugs may help for when you are boosting 16+ but the downside is driveability when not in boost. Other than plugs there is adding octane to the tank which you mentioned or meth/h20 spray, or possibly a much better intercooler.
    2006 spec (40k miles) DD: Getting Turbo'd
    2004 ZO6 supercharged 653RWHP: Sold
    1994 3000gt vr-4 Twin 20g'd 525awhp: Parted out&sold
    Mesa, AZ
    Thanks, i do understand WHY knock happens, and i guess im not gonna know 100% if its the 91 octanes Limit OR the heat from the plugs? Only way to know is to try.
    and fouling the plugs off boost I dont think will happen (well i hope), I make sure to exercise my cars boosting equipment daily
    water/meth injection is something im going to look in to (but i fear they cost allot haha)
    Peoria, AZ
    The cooler plugs will may help a bit with the heat at high boost, it just may effect slight effect of driveability when not boosting such as lowered MPG's due to poor or incomplete burn in combustion chamber. I would try that first. I don't think they'll foul at your high boost levels. You can get a pretty good meth spray kit using your windshield wiper fluid container for $300. It won't have the extra do-dads such as low level warning but it does have adjustable boost sensor (the boost setting you'd want it to kick on). For your application i would do it around 10psi to give it a buffer to kick on and get spraying by the time boost shoots up to 15+. You may have to get some tuning though as it will richen up your fuel mixture.
    Mesa, AZ
    Me have No tuning device LOL so meth might not be for me at this time.
    Im gonna go to the shop, maybe they have a set of the 7 heat range iridium plugs laying around (they have so much stuff lol)
    Peoria, AZ
    You can add 1 gal of xylene to 9 gal of 91oct that'll get you ~93.6octane. Or you can do 2gal of xylene to 8gal of 91 will give ya ~96octane. If you use xylene add a few ounces of mystery marvel oil for lubrication. Xylene is 117 octane. Some people use toulene but thats 114 octane. I haven't bought that stuff in a while, but i use to get it in 5gal drums for about $50 bucks at paint shops.
    Mesa, AZ
    Thats interesting, My cousin does Electrostatic painting (like powder coating for fences) he has xylene always.
    I did stop by the shop, talked to the tech that built my engine, he said 2 step colder plugs (7's) should be perfect for the boost im running. So im gonna try the plugs first, if that doesnt help any, I will try other things.
    No one on here from what i know, uses 7 range plugs with FI, They all stick to 6's so maybe we learn something new?
    Side note, They have a TT 99 Viper GTS Made 1100 lb ft TQ and 980something Horse to the wheels with BONE STOCK INTERNALS!!! @ 14psi.
    Dec 2009
    Sarasota, FL
    I run heat range 6 and I'm N/A, if you are boosted you should have absolutely no problems with 7.
    14.4 @ 97.9mph just bolted
    Hamilton, Oh
    i ran a 2 step colder ngk plug in the sentra on 22lbs. out of boost ran like a champ in boost ran like a champ. i would say a step colder for every 10lbs of boost
    22psi daily=blown up haha
    I ran 2 steps colder for a good while without any issues. Going to try out 3 steps colder soon
    Hamilton, Oh
    let me know how that works. how many psi you hitting?
    Mesa, AZ
    yeah im gonna order the 2 step colder plugs and see how that goes. NGK Iridiums
    Cam stealth is offline
    May 2011
    Perth, Australia
    i run LFR6A. 12psi.
    '02 Nissan X-Trail GT-L. Disco Potato @ 10psi, EMS stinger, LC-1 wideband, FMIC, 440ccs, 3" zorst, Tial MV-S 38mm external gate, 70mm lowering springs, koya drifteks, gauges n shit... bout 280hp @ all fours. Coming soon: S15 coilovers and slotted rotors
    Mesa, AZ
    Quote Originally Posted by stealth View Post
    i run LFR6A. 12psi.
    I also see u run 440 injectors, not good!
  1. Spark plugs
    By m4rty08 in forum B15 Sentra (2000 - 2006)
    Last Post: 11-16-2011, 01:45 PM
  2. pulstar plugs
    By red06 in forum Naturally Aspirated (NA)
    Last Post: 04-06-2011, 03:32 AM
  3. Spark Plugs
    By blackgti06 in forum B15 Sentra (2000 - 2006)
    Last Post: 05-27-2010, 04:29 PM
  4. plugs
    By jonny haste in forum Forced Induction & Supporting Modifications
    Last Post: 10-20-2009, 12:15 PM
  5. FS: h3,9007 bulbs and 1step colder sparkplugs
    By Splash45 in forum Parts for Sale
    Last Post: 06-24-2008, 11:21 PM
