question for the sentra community. i blew my turbo the other day from a bad BOV. i rebuilt it today. i noticed though that my compressor turbine had hit the compressor housing. its slightly scratched. junk or not junk?
4xYEA.
BOOOOOOOOOOOOOOOOOOOOOOOOOSTed.
The housing, should be fine I guess. If you're taking about the wheel, might want to replace it.
I concur with Sammy. Make sure you have the new wheel/shaft balanced.![]()
Curious, how can you tell if a BOV blows a turbo? Shaft play? Leakking out? Fked up fins?
Possibly not opening and causing an overboost on the pipes, but the bearings gave in before the couplers.
molten's got it. and the turbos completely junk. i started the car up with the rebuilt turbo and its shitty. i ordered a new one. i hae a new BOV now so i shouldnt have a problem anymore
4xYEA.
Yeah that was how my T3/4 was originally when I bought it used...just bought a new one, to make less head ache
how long did you run with a broken bov to pull this off? Granted it doesnt take much but sweet jesus.
anyways.. i would replace anything that is out of spec or bad from the abuse that it was put through
Preston
My Photo Album
My flickr
StanceWi.com
TheSpecvBoard.com
TDMImports
Ravage Performance
2004 Nissan Sentra SE-R SpecV
Originally Posted by Specv118
