Page 4 of 4 FirstFirst 1234
Results 61 to 79 of 79
  1. #61
    jason miller spcmiller is offline
    jackson ms
    car: 04 spec v
    boosted: august 10
    mods: t3/t4 57trim 15psi DD 20psi racing, full 3 inch dp back, and lots of others.
    04 specv (robbies old one) boosted 15psi DD 20psi racing currently down for repairs.
    Nissan Prayer- Our father, who art in Nissan hallowed be thy name. Thy KA-T has come, the boost will be done, in Silvia as it is in Skyline. Give us this day our daily kill, and forgive us our bad launches, as we forgive Hondas who launch against us. Lead us not into traffic court, but deliver us from the 5-0. For thine is turbo, and the piston, and the LSD. For ever. Amen!
  2. #62
    Cornelio CORN DOG is offline
    Mesa, AZ
    Car: 02 Spec V (bought New)
    Spooling since: Jan-2011
    Mods:
    Turbonetics Kit dual BB upgrade, CP 8.5:1-89.5mm pistons, K1 Rods, ARP Head Studs, JWT BSR, Toga Bearings, AJUSA MLS Head Gasket, DIY Ported Head Bigger intake ports slightly bigger exhaust, Port matched Lower intake mani to head, Upper mani port matched, TB Ported, all gasket matched, Miishimoto Radiator + Fans, Mishimoto CF Catch Can, Turbo XS Dual Stage Boost Controller AEM UEGO, Aoutometer Boost/Vac Gauge, Stromung 3" Mid Pipe, No Cats, 3" VRS Piping, Vibrant Street Power Flat Black 3" Muffler, Fidanza Aluminum Flywheel, Clutchmasters FX300 Clutch,
    **EDIT** 381Wheel HP + 390Wheel TQ @ 17-18psi
  3. #63
    Member X Balyon85 is online now
    Colorado
    Car....02 Spec
    Spoolin since......September 10
    Mods......Treadstone turbo kit, 630injectors, Turbonetics coldside/intake pipe, koyo radiator, hks ssqv bov, boostin 10 pounds til I get the new motor, VRS 3inch catback with Magnaflo muffler
    Quote Originally Posted by Big J
    We both have day jobs. 2J doesn't keep the lights on or pay the rent, so we can afford (literally) to bash who ever the fuck we feel like
  4. #64
    Dec 2009
    02 spec v 75k
    since 3/18/11
    garrett 57 trim 8psi. everything custom. tubular mani. 3" dp/exhaust. 440s, walbro 255. tial wastegate. hks bov. AEM meth inj.
  5. #65
    Sean seanyx11 is offline
    Apr 2011
    Bulldog Nation
    Car: '03 Spec V
    Boosted on: 6/11/11 (hits the dyno after install this week )
    Mods:
    · Treadstone Turbo Kit w/ Precision Billet dbb 5857 .63a/r 3”in 2”out
    · DEI Titanium Turbo/Downpipe Heat Shielding
    · Treadstone Custom MAF IC Pipe 2.75”
    · Treadstone Custom Straight 3” Intake Pipe
    · 2JR Custom 3” Downpipe
    · Greddy RS BOV
    · Walbro 255 Fuel Pump
    · Deatschwerks 600cc injectors
    · Apexi AFC NEO
    · JWT Turbo re-flash w/ 7200 rev limit
    · JWT 7200rpm Valve Springs
    · ARP Rod Bolts
    · HKS EVC-S Boost Controller
    · HKS Type 1 Turbo Timer
    · Zeitronix ZT-2 Wideband w/ LCD display
    · Zeitronix Boost Sensor
    · Zeitronix Oil Temp Sensor
    · Zeitronix EGT Probe
    · Zeitronix Trigger Box
    · 2JR Vacuum Block
    · 2JR Custom 3” side exit exhaust
    · 2JR Big Bore VQ Throttle Body Kit
    · Outlaw Engineering Thermoblok gasket kit
    · Sun Auto Hyper Voltage GT Voltage Stabilizer
    · Nismo/Sun Auto Grounding Kit
    · Treadstone Magnetic Oil Drain Plug
    · Braille 11.5 lb battery relocated to trunk
    · 2JR Custom Battery Box w/ 2 gauge wire
    · Koyo Aluminum Radiator w/ slim fans
    · Prothane Solid Motor Mounts
    · Aluminum/Delrin Crossmember Bushings
    · ACT HDSS Clutch Kit
    · Exedy/Fidanza 11lb Chromoly Flywheel
    · Stainless Steel Clutch Line
    · TWM Short Shifter Adapter
    · 2JR Aluminum Shifter Bushings
    · Unorthodox Racing Lightweight Crank Pulley
    · JWT Balance Shaft Removal Kit
    · JWT S1 Camshafts
  6. #66
    Pete L8YBUG is offline
    Jan 2011
    Anoka, MN
    Slapped 10 Times in 5 Posts
    Car: 03 Spec V
    Spooling since: July 2011
    Mods: Garrett 60-1, tubular topmount, 3" turbo-back, e85, 7lbs low/soon to be 13-14lbs hi
  7. #67
    Plantation, FL
    Car:
    2004 Sentra 1.8s
    Boosted Since:
    July 5 2009
    Mods:
    Garrett T3 Super 60 Turbo w/ 7.5psi Actuator
    2.5'' I/C Piping
    440cc Injectors
    NGK Iridium Spark Plugs
    HKS V3 SSQV BOV
    JDM Intercooler
    APEXI SAFCII
    Protech Fabrications Log Style Manifold
    2.5" Greddy Spectrum Elite Exhaust
  8. #68
    Glen GlenC is offline
    Nov 2011
    Avondale, AZ
    Car: 2006 Spec-V
    Spooling since: October 2011
    Mods: Treadstone turbo kit at 9psi, walbro 255 fuel pump, SAFC neo tuned (kinda. just hooked up my datalogger to get a better tune hopefully). JWT bsr, catless midpipe, apexi ws2 catback, prothane solid motor mounts and revauto engine tq damper, AEM uego, innovate ssi-4, prosports guages. Some other crap too.
  9. #69
    Apr 2011
    2003 Spec V
    Sppoling for less than a month now
    mods: rods, pistons, cams, crank, 60-1 turbo, hks ssqv (replica for now), tial wastegate (10lb spring), walbro fp, 440cc injectors, act clutch, pnp head, and more which i cant remember
  10. #70
    Norberto Nperez1986 is offline
    Car : 2006 SE-R Auto
    Spooling since : Jan 2012 Just tuned ad dyno'd 10 FEB 12)
    Mods: Holset HY35, 7lbs, HKS SSQV BOV, Custom DP, 440cc inj., 255lph walbro fp, UpRev custom made mapping
  11. #71
    michael pandaspec is offline
    nebraska
    car=2003 SpecV
    boosted since JAN 2011
    15lbs E85
    im dangerous like a fire in a nursing home
    OLD PEOPLE BURNING>>>OLD PEOPLE BURNING
    PUT YOUR HANDS UP!!!!
  12. #72
    Car: 2006 specv
    Spooling since: Jan. 2012
    Mods: Precision billet 50 trim, 9.5psi, essentially treadstone kit, custome 3" cold side, electric cutout, uprev tuned, entirely stock internals (minus BSR) 308whp/314wtq
    More mods in my showoff.
  13. #73
    Mar 2012
    Long Island
    Car: 2003 Spec V
    Spooling Since: March 2012
    Mods: Built and boosted with Precision SC61+ many more mods
  14. #74
    woot woot!! FInally boosted 0n april 18 2012 thanks to 2j racing, awesom folks and great work,A++ .Here are the mods.
    Turbonetics kit installed by 2j racing
    custom 3' mendrel bent exhaust with magnaflow muffler
    3'midpipe by 2j
    2j mainfold intake block
    zetronix wideband o2 sensor
    prosport digital boost gauge
    Exedy or jwt clutch with f1 flywheel, we havent decided which one to put on there.
    t3/t4 turbonetics turbo
    Oh and last but not least installation by joe and justin, and tuning by justin even tho we couldnt dyno cuz my clutch was slipping.
  15. #75
    Mar 2011
    Car: 03 1.8l XE
    Spooling Since: 04/14/12
    Mods: Garrett T3 Super 60, 6psi External Wastegate, Protech Manifold and Dowpipe, 440CC Injectors, SAFC2, Prosport Boost/Vac Gauge, AEM Wideband, 2J Light Weight Pulley, 2.5" Intercooler pipping, ES Motor Mount Inserts, Clutchmasters Stage 2 Racing Clutch, 2x 12" Universal Slim Fans w/ Custom Aluminum Shroud, and others.
  16. #76
    Matt mparris is online now
    Berkley MA
    Car: 2004 SpecV
    Spooling since: December 2011
    Mods:t3/t4 .63/.50 AR hybrid turbo. ~8psi BONE STOCK BLOCK
    4x YEA.
    BOOOOOOOOOOOOOOOOOOOOOOOOOSTed.
  17. #77
    mason customspec is online now
    Jun 2011
    council bluffs, iowa
    Car: 2004 spec-v
    Bossted since: Feb. 2008
    Mods: bsr, return fuel system, 1000cc injectors on e-85, walbro 255, precision gt30r on 18lbs stock motor except the wiseco forged pistons.
  18. #78
    spring hill,tn
    Car: 2002 spec-v
    Boosting since: 4/29/12
    Mods: built block, stiffer valve springs, precision 5858e Turbo, full 3" from Turbo back, and more
  19. #79
    Car: 2004 Pulsar Q
    Spooling since: 5/8/12
    Mods: QG18DE+T - T25, 2.5inch exhaust, split dump pipe, FMIC, 440cc wrx injectors, wrx fuel pump, CS oil distribution block, running @ 10psi on 98ron unleaded.
    Power: 185whp.
  1. new mexico roll call!!!!
    By DAVEO in forum Southwest
    Last Post: 04-20-2011, 03:29 PM
  2. WAKE UP CALL
    By gorilla in forum Video Games & Multimedia
    Last Post: 06-03-2010, 11:14 AM
  3. Boosted B16 Roll Call
    By majormods in forum Forced Induction & Supporting Modifications
    Last Post: 07-24-2009, 02:20 AM
  4. call of duty 4
    By tomspecv in forum Open Bar
    Last Post: 03-20-2008, 03:54 PM
  5. UNOFFICIAL ROLL CALL FOR NOV. 11TH
    By Wickidnis in forum B15 Sentra (2000 - 2006)
    Last Post: 11-13-2007, 09:31 PM
