Page 1 of 4 1234 LastLast
Results 1 to 20 of 79
    Nate atomicguy7 is offline
    Super Senior
    LI
    Thumbs up Boosted Roll Call
    Car: 03 Spec V
    Spooling since: October 2007
    Mods: Precision SC61, 3inch turbo back into ws2 muffler, BSR, 10psi low boost/ 12psi high boost, lots of extras.
    Follow this format:
    Car:
    Spooling since:
    Mods:
    Jef Bacon is online now
    The Wheel Ninja
    Jan 2006
    Jersey
    Slapped 2 Times in 2 Posts
    Car:
    02 spec V
    Spooling since: April 09
    Mods: 50 trim @ 8psi.
    Forum Wheel Ninja
    stock 02's/gxe's/04+ stocks/02 G20 sports/18" volk te37's/17" silver nismo's/16" Gold Advan sa3r's
    ive seen some trannies id fuck
    Car: 2003 Spec V
    Spooling Since: February 2006
    Mods: 50 trim @ 10psi, 3" turbo back and tons of other isht
    Car: 03 SpecV
    Spooling since: Aug. 08
    Mods: Turbonetics kit, 8.5:1 Compression CP forged pistons, Pauter forged connecting rods, ARP L19 rod bolts, Upgraded Chromeoly ring package, NISMO cams, JWT valvesprings, FI-R block guard, AEBS head studs, Nissan bearings, 07 head gasket, JWT balance shaft removal kit, Cryotreated crankshaft, Modified Oil Galleys, DTEC fuel control on top of the reflash, DTEC boost controller, AEM UEGO wideband, Auto meter boost gauge, slotted and dimpled rotors, HAWK HPS pads, Eibach Pro-kit springs, front Koni shock's (rear's coming soon)
    ^-- what are you using for management?
    My ecu was reflashed by turbonetics before my build and I was just running off of that. After the build it was WAY too rich so I have the DTEC fuel and boost controller to tune now. Dtec is similar to an SAFC but has more tuning points and a few more options.
    Nice, I'm using the TN reflash as well and was planning on using it after I drop my built motor in...using AFC to fine tune of course. I don't know anyone else using Dtec...nice to know.
    Ya Dtec is nearly gone now. It was big a few years ago. Gurov used it for awhile and talked good about it. I personally like it better that the other piggybacks I have seen + I got it for really cheap.
    I'm LOVING IT with boost !
    03 SpecV, Turbonetics kit, 8.5:1 Compression CP forged pistons, Pauter forged connecting rods, ARP L19 rod bolts, Chromeoly ring package, NISMO cams, JWT valvesprings, FI-R block guard, AEBS head studs, Nissan bearings, 07 head gasket, JWT balance shaft removal kit, Cryotreated crankshaft, Modified Oil Galleys, Fidanza Flywheel, Clutchmasters Stage 3 clutch, DTEC fuel controller on top of the reflash, DTEC boost controller, AEM UEGO wideband, Auto meter boost gauge, slotted and dimpled rotors, HAWK HPS pads, Eibach Pro-kit springs, front Koni shock's (rear's coming soon)
    Car: 02 spec v
    Spooling since: April 09 on and off lol
    Mods: turbonetics 50 trim, 10-13psi (for now)Build with OEM parts, 07 crank, 07 rods, 350z valve springs, u get the idea.
    Super Senior
    LI
    How are the 350z valve springs? they fit? lol
    it's pretty close for the springs to bind when the spring is completlly pressed in. the head will hold for about 8500k rpms. but of course i'm not gonna go that high lol They fit but not with aftermarket cams, only with stock cams, but if u want it to fit with aftermarket cams u need to shim down the springs and/or buckets. Thats wut i did but i also got my valves cut so i'm able to install huge cams if needed in the future. (if they ever come out).
    BIG AL cupit867 is offline
    QNZ
    boosting since 09/2008
    04 Spec v TN 3" protech dP & mani. DD 20psi
    oh yea the famous split second box AKA Obama Box
    CATCH ME IF U CAN
    bumpitt
    The Wheel Ninja
    Jan 2006
    Jersey
    all Tri-state members so far....
    Forum Wheel Ninja
    Jul 2007
    Queens
    Car: 03 Spec
    Spooling since: June 09
    Mods: TN kit, BC stg2, stock midpipe w/o a catback
    2k4spec;
    u ship my shit?
    blk03specv;
    you ship my shit????
    blk03specv;
    lol but im not black?? lol.. i assume you mean my car haa
    2k4spec;yea lol
    Jan 2007
    massapequa
    car: 2006 spec-v
    spooling since: May 2009
    mods: custom turbo kit...57trim turbo..custom intercooler piping.. bc cams with jwt springs/retainers..carillo h-beam rods..cp low comp pistons..stock crank..jwt BSR..custom 3" turboback exhaust to skunk2 megapower muffler (sounds like a sti)..
    p&p intake manifold..tuned with the split second bo...on 12 psi
    Chris V-spectech02 is offline
    Aug 2006
    Holtsville, Long Island
    car: 03 spec v
    spooling since: march 2009
    mods: JGY 3" cat back exhaust, jwt cams, jwt clutch and flywheel, 8 psi
    Justin Just-N-Tyme is offline
    Virginia
    Car-02 Spec
    Boosted Since-sept 09
    Mods-Turbonetics kit @ 9lbs JWT clutch and Flywheel 2.5 in exahust for now
    Larry limp_noodle is offline
    Jan 2006
    973 | 201
    car: 02 spec v
    boosted since: Aug '09/102,000 miles
    mods: treadstond kit w/ 50 trim, other crap
    car: 03 spec v
    spooling since: August 2007
    mods: Garrett T3/4 57trim, 10psi, 2.5" exhaust & downpipe, jwt cams, jwt springs, SAFCII
  1. new mexico roll call!!!!
    By DAVEO in forum Southwest
    Last Post: 04-20-2011, 03:29 PM
  2. WAKE UP CALL
    By gorilla in forum Video Games & Multimedia
    Last Post: 06-03-2010, 11:14 AM
  3. Boosted B16 Roll Call
    By majormods in forum Forced Induction & Supporting Modifications
    Last Post: 07-24-2009, 02:20 AM
  4. call of duty 4
    By tomspecv in forum Open Bar
    Last Post: 03-20-2008, 03:54 PM
  5. UNOFFICIAL ROLL CALL FOR NOV. 11TH
    By Wickidnis in forum B15 Sentra (2000 - 2006)
    Last Post: 11-13-2007, 09:31 PM
