Results 1 to 20 of 24
Thread: MAF Location
    Dec 2009
    Default MAF Location
    Picked up a used Turbonetics kit from an 04 and I have an 02. I have everything bolted up and ready to go EXCEPT my MAF. I didn't take into consideration that the MAF's are physically different from 02-03's and 04+.
    I've came up with a few different options but I'm not sure which is best.
    Option #1
    I could cut a section of piping out (from the red line toward the filter) and use my stock MAF housing. Only problem with this is that it looks like it may be a tight fit because I will be adding a few inches in length.
    Option #2
    Custom piping. The only problem with this is that it won't be as secure AND the BOV is recirculated. Does it matter if the BOV won't be recirculated with the custom piping?
    I would just cut the intercooler piping and insert the MAF before the throttle body BUT I'm using the treadstone reflash for a tune. If the MAF is located after the turbo, I think I may run into some problems.
    Jeremy jeremy is online now
    calipornia
    Default Re: MAF Location
    aren't the sensors the same size? take it out of the 04 housing.
    Ashwin ash is online now
    You can convert your MAF to 04+ or try to get an adatper for the 02/03 style mafs and cut that 04 one out.
    Slapped 16 Times in 15 Posts
    Putting the MAF before the TB is an option, however, you would then have to relocate the BOV and make it non-recirculative (blow thru), the MAF would then have to be 18" away from the TB and the BOV would have to be a further 18" away from the MAF.
    It's best to simply do the MAF conversion or just get a new flange for the 02-03 MAF and replace the 04 flange on the intake pipe.
    Dec 2009
    Hrm....where in the world would I get a 02-03 flange?
    Dec 2009
    Won't I have to use a SAFC to do the conversion?
    Quote Originally Posted by Ponda View Post
    Honestly, I have no idea. Doing the 04+ MAF conversion is out of the question for you?
    Dec 2009
    ^ Not out of the question - but will I not have to use a SAFC to do the conversion?
    Yes you need one, because you have to raise your idle to 950rpms and you will have to use an air/fuel tuning unit to ensure it idles properly.
    Dec 2009
    ^ Okay - that works but I have one more question.
    Does it matter that the BOV will not be recirculated if I ran custom piping?
    if you're doing custom piping, you can set it up however you want
    What do you have in mind? Where would you locate the MAF and BOV?
    Keep in mind the 18" rule and you'll be fine
    TB > MAF > BOV
    > = 18"
    Dec 2009
    The only custom piping will be from the turbo to the filter. I will be leaving all of the other piping alone. So the BOV will be in it's stock location right before the TB.
    Dec 2009
    Quote Originally Posted by B15NewYork View Post
    TB > MAF > BOV
    > = 18"
    Basically everthing is going to be exactly the same. The only difference will be that the BOV will not be recirculated like it is now. I'm just going to use the stock MAF housing and plug it in between the turbo and filter.
    if the MAF is before the BOV (the turbonetics setup), you will need to recirculate (draw through). The only way to not recirculate is if you put the MAF between the throttle body and BOV (after the bov).
    HOWEVER, there's a setting on the afc that might allow you to get away with keeping the maf before the bov and not running recirc. There's a user on here 'SupraFast' that has his setup this way...shoot him a PM.
    Dec 2009
    Okie dokie - thank for all of the help guys!!!
    would the pipes from the treadstone kit( filter to the turbo and the pipe to the throttle body) work with the pipe from the turbonetics kit?
    Dec 2009
    I'm pretty sure it would.
    The setting on the AFC is Decel-Air, when you PM him make sure you ask specifically about that so he knows what you're referring to.
    i just went thru this whole ordeal with roderick...
    we found it best to basically cut that section out, and have a new piece custom made and welded in.. i have a piece u can weld in for an 02 maf btw.. cuz i changed mine from 02 to an 05
    05 spec - silver
  1. 02-03 MAF Conversion to 04-06 MAF
    Last Post: 04-13-2011, 06:43 PM
  2. FS: 02-03 and 04-06 MAF housing
    By Splash45 in forum Parts for Sale
    Last Post: 08-04-2009, 09:03 PM
  3. nismo sticker location
    By viper_fan in forum Naturally Aspirated (NA)
    Last Post: 05-06-2007, 07:23 PM
  4. Spec V ECU location?
    By BLKFRONTSPEC_V in forum B15 Sentra (2000 - 2006)
    Last Post: 07-30-2006, 04:14 PM
  5. Meet Location Poll
    By B15NewYork in forum B15 Sentra (2000 - 2006)
    Last Post: 05-24-2006, 03:58 PM
