Results 1 to 11 of 11
Thread: 2013 Scion FR-S
    Colton kruton1990 is offline
    Prescott, AZ
    Default 2013 Scion FR-S
    Just reading up on a new scion. looks pretty awesome. redlines at 7400rpms, its a 2L, you can get it as a 6 speed manual and its rear wheel drive. I thinks its going to be the next big drift car. Scion FR-S Colors & Transmission | SCIONFIRST86.COM check it out
    Spring, TX
    I saw this at the Houston auto show last week. Looks absolutely sick. But it's only a 2.0L with 200hp (to the crank probably) I don't think this is going to be a drift car... Especially with the wheel/tire setup it has
    EDIT: The one they had at the auto show had some crazy wheels on it. Like had no lugs or anything. The one one this site is different
    Scion/Subaru/etc. built this car right. Not a big boat like all the other RWD cars out there (*cough* Genesis coupe *cough*). The aftermarket will be huge for this car as well, so don't let the low HP figures bother you.
    Bothell, WA
    Slapped 5 Times in 4 Posts
    That doesn't look too bad.
    ..... << Yuh dun know!!
    Prescott, AZ
    well its a horizontal motor not vertical so they were able to have it lower to the ground i guess like a boxer motor for a lower center of gravity and better weight distrubution. Its got a good stroke for boost and all the SR20 motor is a 2L and its a good drift motor. Its got more power than our car stock given less torque and you can get smaller rims.
    Rico iicbh is online now
    Los Angeles
    Slapped 5 Times in 3 Posts
    Pretty affordable
    Spring, TX
    This is the one I saw
    Sent via Tapatalk
    A big boat for sure. The 2013 turbo one has 274hp though and the v6 goes up to 348hp. So it should make it interesting this time around.
    Anyway, the FRS/BRZ will probably become the next drift cult car. Powerwise will most likely be solved by a turbo. A GT300 car was already built so no doubt the performance scene will pick this car up like its lost child.
    More info on the FR-S: A Tech Look Under the Scion FR-S!
    Good pic of said boats:
    roy risforroy is offline
    shitsville, ky
    there's a turbo version coming from one of the companies. 1.8t i think?
    Im goingto trade my spec v for this bwahaahaha.....
  1. 2013 QR25 Supercharged from Nissan!
    By Joe@2J-Racing in forum 2J Racing
    Last Post: 11-20-2011, 04:04 PM
  2. Supercharge scion tc!! Done!
    By Specvay in forum Open Bar
    Last Post: 06-24-2011, 05:51 PM
  3. scion v6
    By alex_b13 in forum Engine Swaps, Builds
    Last Post: 07-29-2010, 04:48 PM
  4. Scion xB: The 2J goes in everything
    By seeblackrain in forum Video Games & Multimedia
    Last Post: 07-01-2010, 01:59 PM
  5. scion tc
    By FuLLah in forum General Automotive News, Discussions and Rumors
    Last Post: 03-23-2007, 07:44 PM
