Results 1 to 4 of 4
    Default Understanding safc high/low throttle point settings
    an explanation of how safc2 determines and uses both hi/low throttle maps to calculate the adjustment needed.
    It goes off the assumption that throttle plate can be somewhat related to load on the engine.
    so for example:
    lo th=30
    hi th=60
    lo map @ 4000 rpm = +5
    hi map @ 4000 rpm = -15
    lets look at the adjustments it will make, for simplicity sake, lets assume that the engine is rotating at 4000 rpm regardless of throttle posititon:
    0 throttle - lo map only is used , so +5 adjustment to airflow
    10 throttle - lo map only is used, +5 adjustment
    20 throttle - lo map only is used , +5 adjustment
    30 throttle - low map only is used, +5 adjustment
    40 throttle - this is where it gets a bit complicated, it will use both of the maps and interpolate the value between lo and hi adjustment based on the throttle...
    total adjustment points = hi - lo = -15-(+5) = -20
    throttle difference = hi th - lo th = 60 - 30 = 30
    adjustment points per throttle % = -20 / 30 = -0.66
    adjustment at 10% above lo position = 10 * -0.66 = -6.66% towards hi throttle map
    so at 40% throttle the adjustment will be 5+(-6.66)
    so... 40% throttle both maps are used adjustment = -1.66
    50% throttle both maps are used again, adjustment = -8.2
    55% throttle both maps are used adjustmen = -11.5
    60% hi map only is used adjustment = -15%
    70% hi map only adjustment = -15%
    and so on.
    to sum this up
    below lo throttle, only lo throttle map is used
    above hi throttle, only hi throttle map is used
    between - both maps are used on a sliding scale.
    mine... are set at 55 lo - 85 hi.
    hope this helps.
    Nov 2006
    Massapequa
    thats confusing as shit but i think i kinda got it. i just dont understand what the +5, -15 means exactly...what should the number settings and the rpm settings be for a turbo specv? i know i can change my rpms as well on the lo/hi maps
    2001 SENTRA SE LEATHER AND A/C
    2002 CAMARO SS 6SPD
    1999 JEEP GRAND CHEROKEE W/22'S
    2000 TRANS AM W/SOME BIG TIRES
    1966 VW MANX DUNE BUGGY
    2004 SEADOO RXDI W/RIDEPLATE
    2002 ESCALADE PLATINUM W/22'S
    FOR SALE:
    5 FARAD capacitor $200
    1999 JEEP GRAND CHEROKEE LIMITED 90K $6200
    every car is different, i cant tell u what your settings should be. those +5,-15 where examples.
    another example, maybe you'll get this one.
    lets say u want to add fuel, for example, +10 at 1000 rpms low and +20 at 1000 rpms high setting. And you have your throttle point to be set to 10%lo 50%hi.
    That means you will have +10 at 1000k rpms if you do NOT push the gas pedal more then 10%. if you go past 10% it will start getting the corrections of your high settings.
    +10 lo @ 1000k rpms with 8%throttle will remain +10 cuz u havent pressed the gas past 10%. Lets say u push the gas alil harder to 15% then u will see +15 on ur safc.
    thats not that great of an example but think of it this way, if you have your hi set to be 50% that means it will not get your HI corrections until you press the gas half way. If you set your HI at 80% it will not get the HI corrections till u press the gas pedel past 80%.
    Nov 2006
    Massapequa
    okay that makes more sense...
    2002 CAMARO SS 6SPD
    FOR SALE:
  1. All B16 Models GI: Who would buy a B16 4 point Lower Tie Bar?
    By xbrandonx in forum Group Buys
    Last Post: 11-09-2009, 01:57 PM
  2. Replies: 9
    Last Post: 10-14-2009, 09:41 PM
  3. SAFC on a 04 Spec V 100% Throttle Reading
    By punkassazn in forum Tuning & Engine Management
    Last Post: 10-13-2009, 02:58 PM
  4. Low and High Throttle % on SAFC2
    By SupraFast in forum Tuning & Engine Management
    Last Post: 10-05-2008, 08:14 PM
  5. Understanding the Magnuson-Moss Warranty Act of 1975.
    By djtorello in forum B15 Sentra (2000 - 2006)
    Last Post: 06-16-2008, 05:07 PM
