Page 1 of 4 1234 LastLast
Results 1 to 20 of 62
    Corey corey69 is offline
    Jun 2011
    North Alabama
    Default How healthy is your motor???
    Alright I got this idea from another post. If this is a repost mod's please delete it.
    The idea is to post up the mileage on your motor and lets see who has some really high mileage and what they did to make their motor's last that long.
    Like this
    Motor Code-
    Mileage-
    Motor Oil Used-
    Highest and Lowest Tempatures In Your Area-
    How Often Oil Is Changed-
    How Car is Averagely Driven-
    Boost or No Boost-
    Internal Mods to Motor-
    What parts have been replaced(if any)-
    Mileage- 159xxx
    Motor Oil Used- mobil1 5w30 since 15k
    Highest and Lowest Tempatures In Your Area- 105 to 50
    How Often Oil Is Changed- 3-5k
    How Car is Averagely Driven- spritedly
    Boost or No Boost- not boosted yet
    Internal Mods to Motor- BSR
    What parts have been replaced - coilpacks, cam/crank sensors.
    Maybe you should add what parts have been replaced?
    Jun 2011
    North Alabama
    Good Idea Alex!
    Motor Code- QR25
    Mileage- New motor put in at 176k miles, 8k on new motor.
    Motor Oil Used- Whatever Meineke uses, soon to swap to synthetic.
    Highest and Lowest Tempatures In Your Area- High heat index around 115, low around 25 in winter.
    How Often Oil Is Changed- Every 3000 Miles
    How Car is Averagely Driven- Shifts below 3k, about 1 good spirited run a day. (no self control:P)
    Boost or No Boost-None atm
    Internal Mods to Motor- None atm
    What parts have been replaced(if any)- none
    Jun 2011
    North Alabama
    Also mods, if this grows I believe it will be very good information. If you would like to sticky it.
    Pete L8YBUG is offline
    Jan 2011
    Anoka, MN
    Slapped 10 Times in 5 Posts
    Motor Code- QR25DE
    Mileage- 136,000
    Motor Oil Used- Castrol 5w20 from 50k-90k, Brad Penn 10w30 ever since
    Highest and Lowest Tempatures In Your Area- -20*to 100*
    How Often Oil Is Changed- 3k miles
    How Car is Averagely Driven- daily driven (beat to piss daily) in the summer only driven for 2 winters
    Boost or No Boost- boosted since 95k pushing 300whp
    Internal Mods to Motor- Headstuds and Ajusa gasket (strictly preventative), balance shafts removed at 130k
    What parts have been replaced(if any)- Engine warrantied at 60k due to precat failure
    Fuck wheel hop zeno is offline
    Coachella Valley
    Slapped 2 Times in 2 Posts
    MC-QR25
    Mileage- 41,xxx
    Motor oil used- M1 (5w-30,10w-30), M1 EP (5w-30,10w-30), Valvoline Synpower (5w30, 10w30)
    OCI- 3-4k miles
    driving conditions: Desert: 100+F and lots of dust.
    driving behavior: Nissan recommeded shift intervals, but I will open it up at least once a day.
    No boost, no internals, and no major parts replaced.
    Jordan jrushing11 is offline
    Jan 2011
    langley AFB, Virginia
    MC- QR25
    Mileage- 94,000
    Motor Oil Used- Royal Purple 10w30 and 5w30 (depending on season) changed every 3500-4000 miles
    Driving conditions- 110F in summer, 20F in winter
    not boosted
    Driving behavior- aggresive at times... well alot.
    no replacements yet.
    Now in the Subie gang
    Corning, NY
    Motor Code- QR25- 2003 spec v
    Mileage- 136,xxx
    Motor Oil Used- M1 10w40 or equivalent 10w40
    Highest and Lowest Tempatures In Your Area- 95*F summer, -10*F winter
    How Often Oil Is Changed- 3-4k miles
    How Car is Averagely Driven- slightly aggressive, but it isnt beat on
    Boost or No Boost-NA
    Internal Mods to Motor- BSR @ 130k
    What parts have been replaced(if any)- air filter, spark plugs, Header, muffler
    (vehicle aquired with 115k. original engine)
    white 03 spec v
    Lucas Specv03 is offline
    NH
    Slapped 2 Times in 1 Post
    Motor Code: QR25DE
    Mileage: 116k owned since 103k
    Motor Oil Used: synthetic 5w-40 Rotella
    Highest and Lowest Tempatures In Your Area: 50* - 100* doesn't see snow
    How Often Oil Is Changed: 4k
    How Car is Averagely Driven: spirited
    Boost or No Boost: boost since 109k
    Internal Mods to Motor: chain cut and coolant temp mod
    What parts have been replaced(if any): cam/crank positioning sensors, coilpacks, and the oil filter with VQ35DE filter
    *Region/conditions you drive in: open roads, Northeast
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Quote Originally Posted by JVSpecV View Post
    A twin charged, 6 wheel awd, center steer, sqr powered spec v with n2o is no laughing matter.
    Motor Code - QR25DE
    Mileage - 131,xxx miles
    Motor Oil Used - Mobil1 5w30, Castrol Syntec 5w30 and 10w30, now Mobil1 0w40 ONLY
    Highest and Lowest Tempatures In Your Area - 50-100*
    How Often Oil Is Changed - Every 5k
    How Car is Averagely Driven - mostly highway, some spirited driving, some 1/4 runs
    Boost or No Boost - boosted since 115k
    Internal Mods to Motor - BSR and low temp t-stats
    What parts have been replaced - CKP sensor
    Brian b3x02 is offline
    Aug 2009
    Lawrence, MA/ Salem, NH
    Motor Code- QR25DE
    Mileage-66,500
    Motor Oil Used-Mobile 1 Full Synthetic 5w30 (long Trip) Pennzoil Full Synthetic 5w30
    Highest and Lowest Tempatures In Your Area- 15 to 110 (MA/FL)
    How Often Oil Is Changed-3-5k
    How Car is Averagely Driven- Grandpa Daily Driver
    Boost or No Boost- Nope
    Internal Mods to Motor- Nope
    What parts have been replaced(if any)- Nope
    alexis b1ynd is offline
    P.R.
    Motor Code - QR25DE
    Mileage - 77,xxx miles
    Motor Oil Used - Castrol Syntec 10w40
    Highest and Lowest Tempatures In Your Area - 60-105*
    Boost or No Boost - NO BOOST
    Internal Mods to Motor - NONE
    What parts have been replaced - ALTERNATOR and normal maintainance stuff
    Sebastian QR25DE_SpecV is offline
    Jun 2010
    Austin, TX
    Motor Code- QR25DE
    Mileage- 68k
    Motor Oil Used- Mobil 1 High Mileage
    Highest and Lowest Tempatures In Your Area- 20-110
    How Often Oil Is Changed- Every 5k (with JWT BSR)
    How Car is Averagely Driven- Hard
    Boost or No Boost- None
    What parts have been replaced(if any)- I/H/E + BSR
    Perfect compression.
    Jun 2011
    massachusetts
    Motor Code-qr25de 02 specv
    Mileage-238k rebuild@ 153k
    Motor Oil Used-mobil1 synthetic +lucas oil stabilizer(10w-30 summer, 0w-20 winter)
    Highest and Lowest Tempatures In Your Area-(summer-80/90, winter-10/30) fdegrees
    How Often Oil Is Changed-every 5k or before long trips
    How Car is Averagely Driven-grandmas pass me
    Boost or No Boost-stock na
    Internal Mods to Motor-jwt bsr
    What parts have been replaced(if any)-consumables, alternator, 4 throttle bodies, sensors, electronic valves, gaskets, engine overhaul with original parts.
    I also use these consistently as well:
    -Mobil1 ext life oil filter
    -Mobil1 93 oct super+ (or rarely Shell VPower)
    -lucas upper cylinder lube
    I can say when i did the rebuild, the valves and pistons were really clean even with a blown headgasket. I did oil changes starting at 39k, since i had a free 36k service plan at nissan.
    Kevin rosieposie is offline
    Jun 2011
    Apple Valley CA
    Motor Code-Qr25de
    Mileage-162k
    Motor Oil Used-Nextgen 5w30
    Highest and Lowest Tempatures In Your Area-20-130
    How Often Oil Is Changed-3k miles
    How Car is Averagely Driven-depends on my mood
    Boost or No Boost-no boost yet
    Internal Mods to Motor-none
    What parts have been replaced(if any)-Header
    Aug 2011
    Raleigh, NC
    Motor Code: QR25DE
    Mileage: 126k
    Motor Oil Used: Mobil 1 5w30
    Highest and Lowest Tempatures In Your Area: 30-100
    How Often Oil Is Changed: 3k miles
    How Car is Averagely Driven: Hard
    Boost or No Boost: No boost. Will probably stay that way.
    Internal Mods to Motor: JWT BSR
    What parts have been replaced(if any): Alternator, headers, coil pack, spark plugs.
    Mine recently started misfiring. Hopefully it's just another coil pack.
    Damn, everybody has high mileage
    Motor Code- QR25DE
    Mileage- 34,000
    Motor Oil Used- Mobil 1 synthetic, weight depends on season
    Highest and Lowest Tempatures In Your Area- according to weather.com 13-82 on average
    How Often Oil Is Changed- every 3-5k
    How Car is Averagely Driven- spiritedly
    Boost or No Boost- N/A
    What parts have been replaced(if any)- NGK Iridiums, header
    2001.5 S4 APR Stage 3 + more 487 AWHP & 509 AWTQ - Sold
    2004 Cloud White Spec V bolted - DD
    2004 Blackout Spec V bolted - Totaled
    2002 2JZ-GTE/GETRAG swapped IS300- project
    marc czech1013 is offline
    Shelton, CT
    Motor Code- QR25
    Mileage- 85,XXX
    Motor Oil Used- M1 5w30
    Highest and Lowest Tempatures In Your Area- ~ 105/-5 (lol)
    How Car is Averagely Driven- aggressive and economical, half and half
    Internal Mods to Motor- none
    What parts have been replaced(if any)- header
    Branford, CT
    Motor Code- QR25
    Mileage- 104,200
    Motor Oil Used- Mobil 1 5W-30
    Highest and Lowest Tempatures In Your Area- 100F -10F
    How Often Oil Is Changed- Every 5,000 miles
    How Car is Averagely Driven- rarely above 4,000 RPM
    Boost or No Boost- NA
    Internal Mods to Motor- stock
    What parts have been replaced(if any)- none (that I know of)
    (compression test is 180 PSI on all 4 cylinders)
    matthew mattlp is offline
    Gainesville, Florida
    Motor Code-QR25DE
    Mileage-7XXX
    Motor Oil Used-5w30
    Highest and Lowest Tempatures In Your Area-32* -100*
    How Often Oil Is Changed-3k-5k miles
    How Car is Averagely Driven-passive aggresively?
    Boost or No Boost-all motor
    What parts have been replaced(if any)-header-exhaust, intake, datalogger,
  1. motor is out
    By redline_spec_v in forum B15 Sentra (2000 - 2006)
    Last Post: 11-14-2011, 01:21 PM
  2. Motor not original?
    By theaviatora380 in forum General Maintenance
    Last Post: 03-31-2011, 09:33 AM
  3. QR25DE Looking for A Motor.
    By Skinzdogg in forum Parts Wanted
    Last Post: 05-22-2010, 04:24 PM
  4. Motor swap anyone?
    By ash in forum Open Bar
    Last Post: 03-12-2009, 03:19 PM
  5. WTB: Healthy, Stock Rotors for Spec-v
    By DPAKiNG in forum Parts for Sale
    Last Post: 11-02-2007, 08:29 PM
