Results 1 to 6 of 6
Thread: need help
    aaron specvt06 is offline
    Lafayette Tn
    Default need help
    I'm fixing to turbo my 04 spec v and I need some advice on which tuning device would be best? I'm having it tuned professionally and I've heard the safc2 or greddy emanage...anyone care to give me some advice? Also other than the turbo kit is there anything I definantly need like injectors? I've read wrx 440cc's would work...I'm not tryin to go cheap but is there any decent priced injectors that would be good? Any advice/suggestions greatly appreciated
    SAFC + wideband + tune it yourself. 440's will be good up to 8psi or so.
    *edit* Since you have an '04, check out UpRev's Osiris. Best way to tune IMO.
    Lafayette Tn
    Thanks....I'd like to tune it myself but I've read alot saying one wrong tune could blow the engine ....is tuning it really that bad or fairly simple?
    Quote Originally Posted by silverspecv View Post
    Tuning with a piggyback device will result in tune drift in the long run, so even the best professional tune will wander after a bit. Osiris will get rid of that problem however.
    Lafayette Tn
    Alright thanks for the advice ...hopefully ill be posting the results before long
    Lafayette Tn
    I'm pretty new to this ....I've looked up a little info on the uprev Osiris but I'm wondering is there like preset tunes or how does it work?
